#81 |
regards,
Carlos
Sons visiting uncle charlie; http://www.youtube.com/watch?feature...&v=5T76qsvZrdw; http://www.youtube.com/watch?v=Hb_wolQGU5Y |
#82 |
I suppose lineup may be already working on that...i would like to see your work fellows.
regards, Carlos
#83 | |
#84 |
What about a low power version for headphone use?
#85 |
Nice, but with HEXFET + BJT output stage the thermal compensation circuit (Vbe/Vgs multiplier) will have to replace the simple 1k trimmer...
#86 |
No problem it can be voltage/current scaled down and used with BC signal transistors only and IRF's at the output. But please wait untill we set the right topology with lower THD levels, than any version can be properly settled and calculated. Just wait what Nico will say ...
#87 |
@juma
yeah I know that ... in my posted picture you can clearly see it sitting there on the top of the BIGBT
#88 |
Lazy Cat that does not work. You substituted a Lateral MOSFET with a HEXFET. Biasing it is impossible. It switches between 22pA and 82 Amp. I will have to analyse it properly to find the solution. But personally I do not know why you want to mess with the schematic, rather make some real life measurement of what you have and give it a good listen. I will do the same during the week. I remain confident in what you have here is a very good amp.
Jaycee, a low power version is feasible, but you cannot just scale it. You would probably use BD139/140 for the output devices and run it off a +-6V supply, but there would be a number of value changes required. SIM predicts that it could work quite nicely as a headphone amp. It is Lazy Cat's design so I leave it to him to decide. Nico |
#89 | |
![]() The problem is that I write these lines from the sea and can not perform any tests right now, only communicate. ![]() OK we'll try to stick to basic sch, fine tune the values and than make PCB. ![]() As you probably know common topology to all current feedback amps is similar and combined from an input current diff amp, I/V conversion and output buffer, so the last is somehow missing in our primary sch.
#90 |
Lazy Cat, Don't get carried away now. We can reduce THD by two orders of magnitude by using a pre-driver, very little change and remains simple. I am going to bed now but will do some more work and let you know.
Nico |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
