Simple Symetrical Amplifier
Old 9th September 2011, 12:31 AM   #721
Bigun is offline Bigun  Canada
Bigun's Avatar
Hi Hugh,
The trouble is I don't really have space for power supply on-board with 3 channels on one heatsink. I'm not too concerned about it - if I like what I hear I can always scale up to build a no-compromise stereo but for my HT system this isn't warranted. I do like your pcb's though so I'll see if this flat-on-metal approach is feasible.
My version of Eagle doesn't have any blasted library items for a TO-264 package though.
What do you mean by the 'complementary approach' ? (sorry if I'm being thick !)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 9th September 2011, 01:12 AM   #722
AKSA is offline AKSA  Australia
Ah, complementary pairs means transistors identically placed but opposite gender supported from positive and negative rails......
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 9th September 2011, 03:07 AM   #723
Bigun's Avatar
Originally Posted by AKSA View Post
Ah, complementary pairs means transistors identically placed but opposite gender supported from positive and negative rails......Hugh
doh !
I've started the process of drawing a schematic into Eagle, the general concept is attached. The pcb will be around 75mm x 75mm for each channel. Ignore parts choices, those are just convenient to get the right physical package shape and size - it's the toplogy I need to get right at first.
Output stage is 'standard' AKSA / TGM1 / double EF. Any reason to use something different (all BJT) ?
What am I missing ? do I need to make provision for compensation caps ?
Old 10th September 2011, 04:15 AM   #724
Esperado is offline Esperado  France
Banned
It is not a good practice to bypass electrolytic caps with film ones. Not only it do not reduce the impedance in the 10MHz bandwidth, but it increase-it, because the self of the electrolytic (around 15nh) makes a resonant circuit with the film cap. Better to use low ESR (ESL) electrolytics.or use some serial resistance to damp if we want to parallel with films ones.
Old 10th September 2011, 04:43 AM   #725
Sheldon is offline Sheldon  United States
Nico,
I infer that your BJT version is identical to the FET output version, except for the the output devices themselves. Is that correct, or were there other small changes?
Sheldon
Old 10th September 2011, 09:36 AM   #726
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Gareth,
I can recommend the FetZilla mounting style. It saves space, confers very good cooling, and simultaneously mounts the pcb along with the output devices saving brackets, standoffs, and other messy options. And if you incorporate the power supplies too, you can minimise power supply lead inductance and make it easier to get going.
I couldn't agree more, not only that, I recommend you to do it in that manner. First Alex's PCB was like that.
I really like Andrej's complementary approach here, it sims extremely well with almost an evenly descending train of artefacts. My only concern is that you invariably need to set up tight balance between upper and lower halves with consequences for offset control, but aside from that, his approach to avoid AC coupling is inspired and innovative.
Hugh
DC offset is not even an issue in SSA amp, it is in range of +/-10mV no matter what, of course if the input pair is matched and thermally coupled.
Old 10th September 2011, 09:40 AM   #727
Lazy Cat's Avatar
Originally Posted by Nico Ras View Post
This amplifier is capable to operate in VHF band depending on the transistors you choose.
Nico
Linear gain in VHF band, antenna load impedance and still stable as a rock.
Old 10th September 2011, 09:44 AM   #728
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
For Lazy Cat
Marc
Super, go for it !
Old 10th September 2011, 09:48 AM   #729
Lazy Cat's Avatar
Hi Esperado
The praise should go to Lazy Cat, I merely contributed a small portion. I suggested a thread with each design complete with schematics simulation PCB layout and measurements, BOMs, etc. but it never took off.
To be honest my interest in the thread was that the design was just so refreshingly different that I was compelled to add my preferred output devices, the lateral mosfets.
Kindest regards
Nico
Very kind of you Nico. Thank you.
P.S. Some pics pls.
Old 10th September 2011, 09:52 AM   #730
Lazy Cat's Avatar
Originally Posted by Bigun View Post
Hi Hugh,
After feeling a taste of the SSA a no-compromise stereo will come too, no doubt about it.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
