Simple Symetrical Amplifier - Page 72 - diyAudio
Old 8th September 2011, 06:32 PM   #711
Nico Ras's Avatar
Originally Posted by Esperado View Post
Some serial R in the gates of Q7/Q8 ?
You can use gate stoppers if you please or if you have long tracks to the gates, but the amp did not miss behave without them in my layout.
Nico
P.S. I am as pleased with the performance as I was in the first instance when I made it.
Old 8th September 2011, 06:40 PM   #712
Banned
Originally Posted by Nico Ras View Post
The amplifier feed-back loop is low impedance and pretty immune to RF and completely stable but the cap was purely in anticipation for RF pick-up from very long speaker leads and difficult load, it is not Miller compensation it is purely a filter.
This amplifier is capable to operate in VHF band depending on the transistors you choose.
I hope so ;-)
Better use some H at the output than reintroduce RF in the feedback loop with the IM it can create ?
With my own current feedback Amp, i use shielded loudspeakers wires because of that, and grounded chassis on loudspeakers as well. With an audible improvement. (It is not a "magic cable" effect ;-)
PS: I used to show on tv a vhf signal across my amp to demonstrate the bandwidth of it. Very funny. A very heavy video distributor.
Old 8th September 2011, 07:17 PM   #713
Banned
BTW, Nico, first, congratulation for this nice work.
Did-you plan to resume the different versions together in a post or a web site (i can help you on that), with measurements on each ?
According to the clever remarks of destroyer X, did-you plan to design a "Not so simple C.F. Amp from this idea, in order to promote Current feedback with 'nice looking' distortion numbers ?
Current feedbacks amps are so wonderful, so good to listen, and, in the same time quasi unknown, impossible to find as kits, that they, for sure, need some promotion.
Old 8th September 2011, 07:42 PM   #714
Nico Ras's Avatar
Hi Esperado
The praise should go to Lazy Cat, I merely contributed a small portion. I suggested a thread with each design complete with schematics simulation PCB layout and measurements, BOMs, etc. but it never took off.
To be honest my interest in the thread was that the design was just so refreshingly different that I was compelled to add my preferred output devices, the lateral mosfets.
Kindest regards
Nico
Old 8th September 2011, 08:11 PM   #715
Banned
Oh, sorry Nico, i was thinking at Lazy Cat, indeed, for those congratulations and questions. (age is a nightmare). I want to congratulate Idefix too for those wonderful board designs in this thread.
May i have your feeling about lateral mosfets ?
I explain, i had stopped electronic since 20 years, now, and i have no experience with some new products like those. My amp use IGBTs. I know Lateral have an advantage with the negative temperature figure, and it is a geat advantage to get rid off thermal compensation, but how did they sound compared with IGBT or HEX ?
And an other question, out of topic. I do not have any spice simulation experience, neither the softwares. Is-it a long run to learn ? I run an other very good old IGBT's amp, that i would like to modify from voltage to Current Feedback. It would be a way to do-it snappy without taking the risk of burning everithing with oscillation problems ? Just changing the CR path according to the nice idea of Lazy cat ?
Old 8th September 2011, 08:29 PM   #716
Nico Ras's Avatar
My preferred devices are lateral mosfets, I have not heard IGBJT so I cannot tell. Lazy Cat made them and he would be most qualified to make a statement.
BTW I think you are getting old Alex designed most of the PCBs here, I think.
Nico
Old 8th September 2011, 08:42 PM   #717
Banned
Not an effect of age, i was always unable to remember any name i can't correlate with a face: Apologizes to Alex.
But i can recognize a 3055 when it burn with it smell ;-)
Old 8th September 2011, 08:42 PM   #718
Idefixes's Avatar
Send a message via ICQ to Idefixes
Nico
Yes, the whole work is Alexmm duty, i just modify to adapt my own request instead of asking Alexmm to modify.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 8th September 2011, 11:31 PM   #719
Bigun is offline Bigun  Canada
Bigun's Avatar
Looking at my heatsink and the need for 3 channels I don't think I can use any of the really nice pcb designs so far.
I'm going to start playing with a pcb design of my own, which like Hugh's Fetzilla pcb will mount flat onto the heatsink with the power devices sandwiched between the pcb and face of the heatsink.
I don't need gobs of power (+/- 36V rails for power devices to yield 55W rms into 8 Ohm) so 3 channels on one heatsink will be OK and I only need 1 pair of output power devices. Power supply will be strictly separate.
Anyhow, seeing as I'm the 'champion' for an all-BJT version (????) I'll report back if it looks like this is going to work. I need it built in the next few weeks because my HT system will be off-line without it !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 9th September 2011, 12:18 AM   #720
AKSA is offline AKSA  Australia
Gareth,
I can recommend the FetZilla mounting style. It saves space, confers very good cooling, and simultaneously mounts the pcb along with the output devices saving brackets, standoffs, and other messy options. And if you incorporate the power supplies too, you can minimise power supply lead inductance and make it easier to get going.
I really like Andrej's complementary approach here, it sims extremely well with almost an evenly descending train of artefacts. My only concern is that you invariably need to set up tight balance between upper and lower halves with consequences for offset control, but aside from that, his approach to avoid AC coupling is inspired and innovative.
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
