Old 1st September 2011, 08:55 AM   #611
Lazy Cat's Avatar
Originally Posted by styrkv View Post
HI.
The SSAstage and the listening-impresions given by members and constructor looks very promising!
I wonder if this outputstage can be used ?
My simulator says yes, but I`m not a simulatorwisard as some of you are.
I`m in the prosess of building a Amp with this output, ( bought and matched transistors)
but I`ll be happy if I can use SSA instead of the complicatet Electrocompaniet schematic.
Will you actually built it?
Old 1st September 2011, 08:56 AM   #612
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by radio View Post
Hi
Good people (if I understood well) Why not??
thanks
I plane to try SSA with exicon lateral mosfet (that i ahve to purchase)on same rail voltage, but as i have a good stock of MJL3281/1302, the try on SSA could be faster. If you want/can only share your fonctionnel schematic it's good for me.
Marc
website : http://audiyofield.wifeo.com/index.php
Old 1st September 2011, 09:07 AM   #613
radio is offline radio  Macedonia
radio's Avatar
Marc
OK, Let shoot!
Give the display PCB layout with MJL3281/1302!!
Old 1st September 2011, 09:39 AM   #614
Idefixes's Avatar
OK, Let shoot!
Sorry, i don't understand what you mean? MJL3281/1302 can directly replace 2SC5200/2SA1930.
Marc
Old 1st September 2011, 09:54 AM   #615
Toshiba's 2sa1943/c5200 are their replacement for the often faked 2sa1302/c3281
ONsemi brought out their own equivalent and labeled it MJL. They have since brought out a family of similar devices (probably about 30 so).
Old 1st September 2011, 09:55 AM   #616
radio's Avatar
Marc
Give PCB with MJL3281 /MJL1302,....Where do you see the difference practical with 2SC5200/2SA1943???
there is a problem!!??
thanks
Old 1st September 2011, 09:59 AM   #617
It's past the time that you should have downloaded the respective datasheets and compared physical and electrical characteristics.
Old 1st September 2011, 10:08 AM   #618
radio's Avatar
Friends
This is the same as the search for a hair in the egg!
Advertising, ... advertising, ... where are the people .. and where the introduction !!????
Regards !!
P.S.
shades !!??
Old 1st September 2011, 11:28 AM   #619
Smiley 09's Avatar
Default Have a Look . .
radio,
Please have a look here:
MJL3281 /MJL1302
and
2SC5200/2SA1943
Hope this help,
A.
Old 1st September 2011, 11:55 AM   #620
Question is not referred to me but I will build it, just wont to know power of amp MJL3281/1302A 35VDC and have you any other suggestions like can voltage be 40VDC, and bias current?
thanks
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2013 diyAudio
