#581 | |
![]() I guess it's just me the cat and my curiosity, hopefully not killing me.
#582 | |
![]() Yes, always something to discover and improve ... work in progress to be continued.
#583 |
Lasy cat and nico, in goal to drive speakers with "low" inpedance sink (not 1Ohms at all but more classical between 3 and 4) wouldn't it be an advantage to use double die lateral mosfet as Exicon ECF20N20/ECF20P20 or Magnatec BUZ900/BUZ905DP instesd of built in two parallel simple die. The advantage I see in is no matching between parallel devices and room feet gain. I have built several years ago a 2SK1058/2SJ162 (2 pair per rail) amp with +/-36V rail. It was able to drive in my domestical classical use a wide range of speaker sofar as a couple of bookshelf with a 4 ohms/87db scanspeak midwoofer. But what i am unable to do is to say what such an output stage need for modification in lasy cat simple lateral mosfet (one pair sk158//sj162) or in Nico triple pair output configuration => in few words : how to drive such a double die unit.
Marc
website : http://audiyofield.wifeo.com/index.php |
#584 |
Idefix..
would opt for the more resilient BD140/139 pair for the drivers and increasing current to app 10-15 mA.. |
#585 | |
Marc
#586 |
nope would go for Nico's version with the extra driver in the circuit. It has a 100 times lower distortion and a much better drive of the output..
Q-5;Q-6 to BD 140/139, change resistor R11/12 to app 140 ohm and use R13/trimmer to set the Current through the outputs. |
#587 | |
Marc
#588 |
Off topic posts have been removed and moved to a thread of their own. Please confine discussion here to that proposed by the thread title.The OT posts have been moved here: Powering A Tough Speaker (Split from Simple Symmetrical Amplifier)
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#589 |
Hi Miib,
I do not think it is a competition between which output stage is the best, but more so to offer different variations so that constructors have a choice. In my humble opinion the character of the amplifier is dominated by the front end. There is such a controversy regarding sound of MOSFET vs BJT, but I could not conclude that I heard any significant difference between the two output stages, only that they sounded excellent. It would be like comparing performance differences between a red Ferrari and a yellow Ferrari. Maybe I am getting too old. Regards Nico |
#590 |
Ohh.. this was not meant as a competition...But the question was which version to select for a Dual-device output (both laterals-dual dies), hence my suggestion to follow your approach with the separate driver..and as the Fetzilla thread has clearly indicated the lateral fets do benefit from more driving current..and wit 2 pairs, i think It'll be vise to change to the more resilient TO126 types..
Think you have good opinions..don't be humble about them.. )
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
