Simple Symetrical Amplifier
Old 29th August 2011, 05:20 PM   #551
Nico Ras is online now Nico Ras  South Africa
Nico Ras's Avatar
Alex, I am now tired of complimenting you :-)))
Old 29th August 2011, 05:30 PM   #552
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by alex mm View Post
...... PCB without relay , maybe more elegant , and with larger heatsink
I expect QC to do the job , and I will post PCB rev 1.8 in B&W .
Alex.
QC started ... now
Old 29th August 2011, 06:07 PM   #553
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Nico, post 548 is a Rush Cascode.
Old 29th August 2011, 06:20 PM   #554
Here is a circuit that uses the Rush Cascode :
http://gaedtke.name/SubMenu_Verstaer...ompDiffAmp.pdf
Old 29th August 2011, 06:25 PM   #555
Lazy Cat's Avatar
Alex.
QC report:
- face BJT's in left current source like on the right
- resistor between 4,7V and 15V zeners is 2,2k/2W (two)
- 1uF capacitor between 4,7V and GND is missing (two) very important GND decoupling (to input GND)
- parallel to 10.000uF put also decoupler cap 1uF/63V 5mm pin dist
- IRF gate resistors 000 are actually 47ohm degeneration resistors (silk change)
- please put 2 oposite gate protection zeners on each IRF like in SSA Basic, I will put them in sch later
- IRF9610 Source and Drain are mixed, it should be the Source to Base 2SA1987 and Drain to Base 2SC5359
- GND (SPK -) faston in between existing GND connectors is missing
- this SSA is more powerful than SSA Basic, so all the output traces should be thicker
That's the report from QC department.
Alex you are the best, regards Andrej
Old 29th August 2011, 06:33 PM   #556
Nico Ras's Avatar
Thanks.
Old 29th August 2011, 09:04 PM   #557
odysseybmx414 is offline odysseybmx414  United States
Alex.
Great boards latest ones alex! Especially without the diodes and output relay (although easily jumpered). I'm liking the higher voltage. +-50V is what I've got available to use, and I want to build this version (+-50V BIGBT). But, I don't have the +-60V for the front end.
Old 29th August 2011, 09:27 PM   #558
terranigma is offline terranigma
terranigma's Avatar
I don't understand why people here struggling with this BIGBT thingie that much. Was SSA standing for "Simple" Symmetrical Amplifier?
Old 29th August 2011, 09:28 PM   #559
alex mm is offline alex mm  Romania
alex mm's Avatar
Default PCB rev 1.8 corrected
....... last correction of last rev 1.8 of PCB
Alex.
Old 29th August 2011, 10:24 PM   #560
Lazy Cat's Avatar
Here you have the proposal for +/-60V for SSA front-end power supply. Actually it is complete power supply for one SSA BIGBT High Performance channel.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
