Old 29th August 2011, 12:10 PM   #541
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Lasy Cat, sorry for your mistaken name....and thanks for answer. 50V. 0.5A per rail are the just power rating Or it could be less? I haven't tranny with so such output but i have 2 nice Rcore 500va 2x36V...
Marc
50V/0,5A is the VAS power supply, so it will suck few Watts only and can be also only 50V/0,1A, but the secondary winding wire diameter must withstand 4.700 uF capacitor charging current at power-on phase.
Old 29th August 2011, 12:34 PM   #542
styrkv is offline styrkv  Norway
Lazy Cat.
It`s a clever little circuit you have made there!
To alter the gain, the only resistors to change is feedback resistors, or do I have to change the ground resistors as well.
Old 29th August 2011, 01:03 PM   #543
Lazy Cat's Avatar
Originally Posted by styrkv View Post
Lazy Cat.
Global closed loop voltage gain is related to ratio 2k/100+1, so in your case 21. Open loop voltage gain is another story involving Re, Rc, VAS source impedance, etc.
P.S. Leave 100 ohm GND resistor as it is. If you change the values of the four current feedback resistors you change the fb loop current and therefore you influence the frequency bandwidth too. Please see the CF amplifier references in Wikipedia.
Old 29th August 2011, 01:08 PM   #544
Is it +1?
What if the resistors in the NFB were 1k & 2k. Is the gain 2times or 3times?
Old 29th August 2011, 01:20 PM   #545
Lazy Cat's Avatar
Originally Posted by AndrewT View Post
Is it +1?
It is +1
In a case of 1k and 100 ohm feedback resistors the output voltage is exactly eleven times higher than the input voltage, please find it for yourself, it is logical.
Your example: 2k/1k+1=3 (times)
Old 29th August 2011, 03:38 PM   #546
Nico Ras's Avatar
Hi Andrew,
Gain is the same as for non-inverting differential, in fact you can reduce the schematic to two complimentary symmetrical differential amps.
Gain = (RF + RS)/RS = RF/RS + 1
where RF = R feedback; RS = R shunt
Kind regards
Nico
Old 29th August 2011, 03:40 PM   #547
Thanks for confirming that the gain is not that of an inverting opamp.
Old 29th August 2011, 03:57 PM   #548
Nico Ras's Avatar
Andrew,
cast you mind to the late 70's early 80's, I cannot remeber the guy's name but he introduced the differential amp made of P and N transistors. Maybe Hugh can recall his name.
Nico
Old 29th August 2011, 04:07 PM   #549
terranigma's Avatar
Originally Posted by Nico Ras View Post
Andrew,
Nico
I was waiting for a chance for ask if SSA input stage suitable for modifying it to a differential input stage without referencing the signal to ground. Maybe this will benefit avoiding a cap at input for blocking possible dc.
Old 29th August 2011, 04:56 PM   #550
alex mm is offline alex mm  Europe
alex mm's Avatar
Default PCB rev 1.8
...... PCB without relay , maybe more elegant , and with larger heatsink
I expect QC to do the job , and I will post PCB rev 1.8 in B&W .
Alex.
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2013 diyAudio
