Simple Symetrical Amplifier - Page 54 - diyAudio
Old 29th August 2011, 09:22 AM   #531
styrkv is offline styrkv  Norway
How do you make the thumbnails that pops up to full size when one clicks on it?
I`m not a computerwisard either.
Old 29th August 2011, 09:24 AM   #532
I think it is simply a case of "manage attachments".
DIYaudio does it for you.
Compress your file from .BMP to some other that gives good definition and small file size. Try .PNG
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 29th August 2011, 09:38 AM   #533
Thank you Andrew T.
I`ll try it.
Have you looked at the schematic?
Old 29th August 2011, 09:52 AM   #534
I try again.
Old 29th August 2011, 10:13 AM   #535
Lazy Cat's Avatar
Exclamation SSA BIGBT Basic PWS
Originally Posted by Idefixes View Post
Lasy car you have treasur of transistors. I look around and 2sa1478/2sc3788 are quite difficult to find...
How have plan to provide +/-60V ?
Marc
Yes I know, they are special transistors. Look to BF471/472, BF871/872, 2SC2911/2SA1209 or similar TO-126, 60MHz and higher transistors.
Here's how you get +/-60V.
P.S. I am a Lazy Cat not a car.
Old 29th August 2011, 10:55 AM   #536
Lazy Cat's Avatar
Originally Posted by styrkv View Post
Thank you Andrew T.
I`ll try it.
Hi styrkv
Your sch looks very promising, if you calculated all stages bias currents it will work. SSA front-end will do the job.
Old 29th August 2011, 11:29 AM   #537
Lazy Cat's Avatar
I`m in the prosess of building a Amp with this output, ( bought and matched transistors)
but I`ll be happy if I can use SSA instead of the complicatet Electrocompaniet schematic.
SSA is very simple front-end, symmetrically low-Z GND referenced, consequently resulting in low noise, high stability, minimal DC offset and because of the CF loop, very high speed.
Old 29th August 2011, 11:40 AM   #538
Thank you Lazy Cat.
It`s not fully tested for biascurrents for the front with the higher rails, but I`ll make myself a inputcard and try it out.
The output schematic is from Electrocompaniet AW 120 DMB, with one extra op-pair and emitterresistors
Old 29th August 2011, 11:56 AM   #539
Idefixes's Avatar
Send a message via ICQ to Idefixes
Lasy Cat, sorry for your mistaken name....and thanks for answer. 50V. 0.5A per rail are the just power rating Or it could be less? I haven't tranny with so such output but i have 2 nice Rcore 500va 2x36V...
Marc
website : http://audiyofield.wifeo.com/index.php
Old 29th August 2011, 12:02 PM   #540
Lazy Cat's Avatar
Thank you Lazy Cat.
SSA's front-end collector current is not rails potential dependant as long as they are higher than 15 V. The only limiting parameters are cascode BJT's Vcemax and Pmax.
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
