Simple Symetrical Amplifier
Old 28th August 2011, 03:19 PM   #521
AndrewT is online now AndrewT  Scotland
Originally Posted by Lazy Cat View Post
I know what's on your mind, something like this or even more outputs.
your link took me to post501.
Where was I supposed to go, to see "this"?
regards Andrew T.
Old 28th August 2011, 04:14 PM   #522
Lazy Cat is online now Lazy Cat  Slovenia
Lazy Cat's Avatar
Click on the link automatically redirect me to post #347
Old 28th August 2011, 04:54 PM   #523
takes me to post347.
whereas
takes me to post501.
regards Andrew T.
Old 28th August 2011, 09:06 PM   #524
alex mm is offline alex mm  Romania
alex mm's Avatar
Smile PCB rev 1.7
......have layout rev 1.7 with few pices of wires , PCB not tested !
Alex.
Old 28th August 2011, 09:25 PM   #525
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Excellent layout!
Nico
P.S. you have two IRF610, one should be 9610
Old 28th August 2011, 09:46 PM   #526
alex mm's Avatar
..... thanks Nico , you right , the IRF 9610 it's from minus voltage rail corrected .
Alex.
Old 28th August 2011, 10:59 PM   #527
Lazy Cat's Avatar
Hey Alex you read my mind, great
Today I just started prototyping exactly this sch as you can see on the pic. But the board, hehe will check it tomorrow, it looks sooo good. Many thanks to you Alex and to all SSA thread followers.
Old 28th August 2011, 11:49 PM   #528
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Lasy car you have treasur of transistors. I look around and 2sa1478/2sc3788 are quite difficult to find...
How have plan to provide +/-60V ?
Marc
website : http://audiyofield.wifeo.com/index.php
Old 29th August 2011, 03:58 AM   #529
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Lazy Cat,
A few question here;
1) Can you please post the parts listing for SSA BIGBT 1.1 and the version that uses Lateral MOSFet [rev. 1.4 on Alex MM PCB], in order for us DIYer see the specified rating for each part, also it would be very helpful if you can include possible substitute for the given devices. I will be checking my local supplier if these devices is available to them.
2) Will it be possible to use any suitable PSU+DC protect on this amp? [I am thinking of using one of APExAudios’ PSU design] Hopefully APEXAudio will allow me... It is very encouraging for a DIYer like for an amp design that includes DC protect on board, however my interest is on both L-MosFET and BIGBT Basic that uses 24VAC supply. Any plans in including DC-protect on these versions?
NICO RAS,
Your PCB version is of different kind, will you share the PCB lay-out for etching?
Alex MM,
Please to not tire in providing remarkable PCBs to DIYAudio for without it, DIYer like me will surely find building an amp to be a very tedious and slow progress. Your continuing effort is surely invaluable. Thank you!
It was reassuring to know that authorities on amp building in DIYAudio has been complimenting a lot on the SSA design, the likes of AKSA, DESTROYER X, WaHAB, MiiB, AndrewT...to name a few and of course NICO RAS.
ACO
Old 29th August 2011, 10:13 AM   #530
styrkv is offline styrkv  Norway
Default SSA BJT EC AMPLIWIRE-STYLE
HI.
The SSAstage and the listening-impresions given by members and constructor looks very promising!
I wonder if this outputstage can be used ?
My simulator says yes, but I`m not a simulatorwisard as some of you are.
I`m in the prosess of building a Amp with this output, ( bought and matched transistors)
but I`ll be happy if I can use SSA instead of the complicatet Electrocompaniet schematic.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
