#41 |
Odd order artifacts is a little on the high side. H3, 5, 7 and 9 contributes most of THD. Increasing the quiescent current to around 1.2 amps does change the order to even and lowers THD from 1.6% to 0.4%
#42 |
Sorry I should have qualified it, at an output swing of 24V peak.
#43 |
Is this simmed or built and tested? I understand the two can be quite different.
#44 |
Hi Buzzforb, it was simulated in microCAP. And yes, in practice it could be several orders of magnitude worse.
#45 | ||
You are suggesting a very high bias ClassAB amplifier. |
#46 |
Hi Andrew, as I have said the artifacts are very high and odd order while running it in class AB, in other words low quiescent current.
Pushing it into class A works nicely and all the odd order stuff goes away. In my opinion it will make a rather nice class A amp. |
#47 |
Class Ab @ 1 kHz fundamental
#48 |
Andrew, the efficiency of class A is very low, power loss can be as high as 75% that is why high power class A is not that popular simply because the power supply and heat sink is uneconomical in relation to output power. But it does sound nice, so the toss-up remains whether irritating the neighbors is more fun than listening to music.
#49 |
...... few minors changes , and you can see the new PCB rev.1.1
It was my plesaure to do this board , but can be layout again if not ok Alex. |
#50 |
Hi Lazy Cat, any reason for using power transistors. In fact you can use the same small signal devices throughout. Alex are heat sinks necessary, these transistors hardly dissipate 50 mW.
Other than that, you laid a great board Alex! |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
