Simple Symetrical Amplifier
Old 12th August 2013, 06:14 PM   #4071
Stee is offline Stee  Italy
Stee's Avatar
not yey - i have problem with pcb - do you know how made PCB from schematic?
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 12th August 2013, 06:42 PM   #4072
Esperado is offline Esperado  France
Banned
Originally Posted by Esperado View Post
bigbt is the name (given by L.C. ?) .
I hope everybody had understood that it was a joke. I made-it because, if you search on Google for BIGBT, the only inputs in the first pages are from L.C threads.
Old 13th August 2013, 06:58 AM   #4073
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Thanks guys for explanations given.
Best regards, LC
Old 15th August 2013, 03:07 AM   #4074
woofertester is offline woofertester  United States
Is it possible to get gerber files for V1.4 PCB, copper, drill, tool, silk?
I would like to build this through hole board and experiment with it.
Old 26th August 2013, 09:07 AM   #4075
Cuda is offline Cuda  France
Hello,
What must I change on the schematic if I replace the LATFET SSA with Sanken STD03 thermaltrack darlington ?
Old 1st September 2013, 04:39 PM   #4076
shaan is offline shaan  India
shaan's Avatar
Hi.
I think you should send a PM to Nico Ras for the files.
All the best and happy listening.
shaan
PeeCeeBee V4 Group Buy!
Old 2nd September 2013, 03:05 AM   #4077
Hey guys
I will soon be building V1.4 of the original SSA. Schematic is attached.
I will be using KSC1845/KSA992 for Q1-Q6 due to the ability to make matched pairs. I have had no success matching medium power VAS transistors so far.
I would like to run the VAS at 5ma. 10mA will probably cook the VAS transistors.
Is the VAS current set by VR1? If I set the VAS at 5mA what do I change to get the outputs to bias at 130 mA?
http://www.diyaudio.com/forums/attac...er-design1.pdf
Old 6th December 2013, 09:04 AM   #4078
Buhl is offline Buhl  Denmark
Buhl's Avatar
Default SSA info??
Hi Guys
Would like to build a SSA amp - but after looking around in the various threads, I'm getting a bit confused - several versions, different transistor versions etc.
I can't seem to find a thread which compiles info for a given version: schematic, Bill of materials, known issues etc. ??
Will I have to go through all +500 pages to learn this ?
Best regards
Hans
"Calculations? We don't need no stinkin calculations! We just make them really big!" Quote: Nelson Pass
Old 6th December 2013, 12:43 PM   #4079
Lazy Cat's Avatar
Hi Hans, welcome to the thread
Well any SSA inclusive amp's name will give you listening pleasure it's just about your DIY skills, but looking to your forum's registration date I assume there's no such limitation.
Without any doubt for the start I would suggest you PMI's VSSA version or Bory's BJT/hexfet VSSA version of this amplifier. All are CFA with CCS to inject input bias current, high bandwidth, high speed amplifiers. Latter is a little bit powerful but all depends on your speakers to choose the right one.
So much for the introduction.
Old 9th December 2013, 11:42 AM   #4080
Buhl's Avatar
Hi Lazy Cat - and thanks for the welcome!
My DIY skills are not that high - even though I'm an "old dog" in here, I can't do many tricks. I've build a couple of preamps and class A poweramps, all Nelson Pass designs - and a bunch of chipamps - but am by no means an Expert in anything - I own a voltmeter and a soldering iron, that's it
I kinda like the sound of chipamps, but find them to weak to some extent, and also like the class a amps, but I want something which can be turned on all the time - then a bit simple - and Thus found this thread
I can see that PMI has some good documentation - but I need to ask which transistors should be matched - all of them? I know from the pass-world that symetrical devices sharing a signal should ideally be matched if there's high gain involved?
Best regards
Hans
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2017 diyAudio
