Simple Symetrical Amplifier
Old 5th April 2013, 05:33 PM   #4031
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
For those, like yours trully, that know nothing about IGBTs:
IGBT tutorial: Part 1 - Selection
M.
Old 6th April 2013, 10:11 AM   #4032
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by maxente View Post
I known it's a must an osciloscope, but unfortunately i don't have one
Borrow one, it is essential.
Basic rule to connect newly made DIY amp to power supply, is to connect both DC rails via serial resistors 22-33 Ohm/10 W which serves to protect the amp and output transistors from failure in a case of a wrong assembly or oscillations. This also enables to perform measurements in such abnormal conditions safely.
Old 18th April 2013, 01:12 PM   #4033
maxente is offline maxente  Romania
maxente's Avatar
Today I have some time to measure some voltages
First I connect to GND all the pcb traces used for normal rectifier and replace those fuses with 33ohm/10W resistors
This is good because oscilations are gone, now i can measure voltage on any point of schematic with no problem at all
Here is what i measure so far
Old 18th April 2013, 07:38 PM   #4034
Hlaford is offline Hlaford  Croatia
I wonder, BC550 and BC560 at Rbb~150 ohm are maybe not the best match to BF471 and BF472. Perhaps some lower Rbb transistors would further decrease the noise floor?
Just a thought.
Old 23rd April 2013, 02:20 PM   #4035
400kg is offline 400kg  Turkey
Banned
Send a message via MSN to 400kg
Default ssa edit
hi dear Lc
whether you want to use such an arrangement to ssa
Is there a spot you want to correct?
Old 23rd April 2013, 02:31 PM   #4036
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 Simple Symetrical Amplifier
Uploading as image (from @400kg).
Max.
Old 23rd April 2013, 04:19 PM   #4037
Belaji is offline Belaji  United States
Default Another SSA Variation
Here's my take on LC's great amp!
Old 23rd April 2013, 11:36 PM   #4038
Lazy Cat's Avatar
So now you have good starting ground to calibrate SSA to working conditions.
You're not so far away, indicated from your measurements values, DC offset should change in both directions and finally set it to zero. Bias through each output BJT should be 100 mA and when you'll come to this conditions, you can freely disconnect safety serial resistors and connect SSA directly to PSU via 5A/T fuses.
Old 23rd April 2013, 11:38 PM   #4039
Lazy Cat's Avatar
WOW nice take, just needs to be realized. Any obstacles?
Old 24th April 2013, 12:03 AM   #4040
Lazy Cat's Avatar
Originally Posted by 400kg View Post
hi dear Lc
Yes, according to all experiences gained from SSA, TSSA and VSSA I would change input current injection point, since that improves thermal stability into rock solid as in VSSA.
That complexity of the amp would be disastrous if it would have unstable output bias and if it would walk around zero DC like a drunker, also in this way you won't need any DC servo at all.
So how to make it hehe, let me see your approach and if you cannot transform and adapt it, I'll help.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
