Simple Symetrical Amplifier
Old 14th February 2013, 05:43 AM   #3951
shaan is offline shaan  India
shaan's Avatar
Let me share this interesting phenomena that's common to the CFB amps I build.
Whenever I touch the input pin while wearing my slippers the amp comes alive and a lot of AM stations can be "tuned" just by varying my grip on the input pin. The signal is quiet clear and has better fidelity than commercial AM tuners. The show stops if I touch the floor or the input ground. Funny anomaly.
V4 GB! | V4H GB!! | PSU GB!!!
Old 14th February 2013, 06:49 AM   #3952
Nico Ras is online now Nico Ras  South Africa
Nico Ras's Avatar
Shaan,
you must have a long aerial
Kindest regards
Nico
Old 14th February 2013, 07:06 AM   #3953
sofianirawan is offline sofianirawan  Indonesia
good afternoon mr.shann, mr.LC.saya want to assemble a klass amp ssa that, I read the article from the power amp bonsai if no one power amp pack assembly results bonsai nx and sx type .... I've assemble and mr.nafiri ssa power amps ... melodious voice, pleasing to the ear and pain in telinga.apakah mr.shaan, lc is assembling a klass amp?
Old 14th February 2013, 08:11 AM   #3954
shaan's Avatar
Originally Posted by Nico Ras View Post
Shaan,
Old 14th February 2013, 08:35 AM   #3955
Esperado is offline Esperado  France
Banned
And special audiophile slippers.
Old 14th February 2013, 11:32 AM   #3956
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
Seems that now the oscillations are under control.
I soldered another 100 ohms at the gate of the mosfets (they're wired, not soldered directely to the board for now) and twisted the PSU cables.
The input cable is of very bad quality. It's not shielded and has been bitten and chewed many times by my cat. It's been soldered that many times after the bites. My cat bites every cable he can find.
The filter capacitor is at 330pF now with the 1K paralleled resitor to ground. Why did you choose only 20pF?
I still ear some noises from the radio but now it's not a whistle, it's noise. When I connect the input cable the noise increases. Is this an oscillation too or it's normal?
Thank you again for your help guys.
Kind Regards,
Paulo.
Old 14th February 2013, 02:11 PM   #3957
Sorry about that. What I meant is:
The 1K resitor is in series with the input. The 330pF cap goes to ground and it's paralleled with a 10K resistor. Now it's good
Kind Regards,
Paulo.
Old 14th February 2013, 03:35 PM   #3958
keantoken is offline keantoken  United States
keantoken's Avatar
This is why I use an RC snubber across the input. Ideally the input would be buffered so this wouldn't happen. Just like an amplifier may anomalously oscillate into specific loades, it may also oscillate with specific sources. Oscillation may cause DC offset or otherwise destroy the speakers.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 15th February 2013, 01:56 AM   #3959
Banned
This had been said to you previously.
Old 15th February 2013, 09:05 AM   #3960
I was just correcting my previous post because it sounded like I had a 1k resistor paralleled with 330pF. It was too late for editing. What "sounds good" is not the amplifier (wich now sounds good but for other reasons) but my post.
Kind Regards,
Paulo.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
