Simple Symetrical Amplifier - Page 394 - diyAudio
Old 11th February 2013, 09:14 AM   #3931
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
www.esperado.fr - Accueil - Alimentation Crescendo
Thank you
I have two questions:
Could the BDY's be replaced by a single more powerfull transistor like SC5200?
What's the role of the TL431 if the zeners are in place?
Thank you again.
Kind Regards,
Paulo.
Old 11th February 2013, 10:53 AM   #3932
shaan is offline shaan  India
shaan's Avatar
Hi paulo.
The precision zeners are there to fine tune the output voltage to match the + and - supply close in value, within millivolts.
PeeCeeBee V1.1 Here, V2 Here and V3 Here
Old 11th February 2013, 12:06 PM   #3933
which is the schematic of shaan SSA with Servo?
Didiet
Old 11th February 2013, 03:16 PM   #3934
Shaan any news on PCB fabrication from your side ?
Jhonny
Old 11th February 2013, 04:39 PM   #3935
Banned
Originally Posted by PauloPT View Post
TCould the BDY's be replaced by a single more powerfull transistor like SC5200?
Of course, but remember you will need, anyway, a soft start if u use big caps.
TL431 is an adjustable Zener, Nor able to go high enough in voltage, thus the need of the other zeners to add their own, that you will chose according your need.
Old 11th February 2013, 04:55 PM   #3936
Originally Posted by shaan View Post
Hi paulo.
Hi Shaan, I think you forgot to include on your SSA Impotant Links on how to do the biasing on your SSA amps. I'm for sure it will be helpful to eveyone who is attempting to build it, specially on the first power up of the amp. Just my two cents.
Fred
Old 11th February 2013, 06:26 PM   #3937
So, Im fairly to new amp building, have built one amp recently and a few kits many years ago. Im looking for a new project and find this to be a circuit id like to build. It looks like a lot of time and energy has gone into this, and I cant wait to start.
Old 11th February 2013, 06:50 PM   #3938
Fred
You don't need to bias the amp, the 2 1N4148 set the bias for the fets. You need to ajust the dc offset with the trimpots or use the servo version instead.
Kind Regards,
Paulo.
Old 11th February 2013, 06:52 PM   #3939
How much current goes trough the zeners?
How many volts should be across the transistors? (vin-Vout)
thanks
Kind Regards,
Paulo.
Old 11th February 2013, 07:18 PM   #3940
Banned
I is Set by the 380 Ohm. (V=RI) need ~ 1/100 of the requested output current.
Vin-Vout/Vin is perfect around 7%: More, you need more power dissipation for the power transistor, less, you have less margin when AC flows or high demand. Tune-it to let a little margin when full power with the amp on its charge.
If it is too complicated, just change the Zener total values to let 25/30V in the TL431, according to your V.
It is the simplest stabilization you can find, so simple that i think it need no further out of topic explanations.
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
Copyright 1999-2017 diyAudio
