#3911 | |
Hi shaan.
Kind Regards, Paulo. |
#3912 | |
Location: Scottish Borders - Kelso; on the famous Tweed River!
I too know little about solid state design and especially heat-sink requirements. Run as shown in red in the quote above, what is a safe minimal heat-sink requirement per channel? I can wait until you return for a response! Many thanks. |
#3913 | |
My rough guess is a 0.5degC/W heatsink per channel. You can see I am no expert in heatsink designing. However, I use a p4 CPU heatsink with the 12v fan running at 6v, per channel. And this works well at full power output. If you try this I doubt you'll be disappointed. shaan
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#3914 |
Thank you Shan...I am sure your temperatures 'near the Ganges' are a lot higher than ours here in Scotland!
That gives me a good clue that the heatsinks I already have will do - at least for testing. |
#3915 |
My pleasure Brian. But, do you really need heatsinks in Scotland? Well London may need sinks though, in mid summer.
#3916 |
It is very simple. If V is the power supply voltage ( "V+" + "V-" ), and Rl the impedance load, the max dissipated power will be: Wdiss = VČ/(19.75 x Rl). for a class B amp.
You add the thermal resistance of the device, isolator if any, and radiator and you get the total thermal resistance. Now, it is easy to calculate the max temperature. Last edited by Esperado; 7th February 2013 at 10:57 PM. |
#3917 |
If you allow the temperature junction to reach 150° when atmospheric air is at 50°, you need a temperature delta of 100°.
You have to know the power of your transistor at 25°. Now, you divide 25 by this power to know the internal thermal resistance of your transistor. lets call this "K" You add the thermal resistance between the case of your power device and the radiator for a mounting with thermal grease. Lets call this 'D" Multiply this D value by two if you add a isolation material, and add the thermal resistance of the isolator itself. Now, you have the total thermal resistance of the mounted transistor by adding "K"+"D" = "R". Divide this value by the number of power device you will use: "S". P is the power value you need, according to the last post. We need "T"= 100/P of total thermal resistance. T-S will give-you the maximum desired thermal resistance of your radiator. Any value less than that will feat. Yes, i know, it is boring to calculate. |
#3918 |
Hi shaan,
I've been doing simulations with LTSpice. I get a lot of harmonics. See the pic below. Is this a concern or just a simulation glitch? Thanks
#3919 |
Hi paulo. We need to see the schematic you are simulating. At what output voltage and load resistance was this FFT taken?
#3920 |
H2 is at -75dB from the signal level, (<0.02%) what the hell ?
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
