Simple Symetrical Amplifier
Old 3rd February 2013, 12:02 PM   #3881
Esperado is offline Esperado  France
Banned
Originally Posted by PauloPT View Post
Do you find the servo doesn't impact negatively the sound?
The most common error is to consider servos outside from the signal path. They are in. So it is necessary, if you are looking for the best performances (and sound quality) to care about the IC performance (ultra low distortion and noise) and cap quality. If you achieve-it, and if the FC of the servo is low enough to have no phase shift in the audio range, you will have no change on sound signature.
Old 3rd February 2013, 12:06 PM   #3882
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
The most common error is to consider servos outside from the signal path. They are in. So it is necessary, if you are looking for the best performances (and sound quality) to care about the IC performance (ultra low distortion and noise) and cap quality. If you achieve-it, and if the FC of the servo is low enough to have no phase shift in the audio range, you will have no change on sound signature.]
Has this servo being designed in such a good way? Should I go for this circuit?
Kind Regards,
Paulo.
Old 3rd February 2013, 03:29 PM   #3883
Banned
What is the IC you gona-use ?
Old 3rd February 2013, 03:38 PM   #3884
TL072. Should I use other?
Kind Regards,
Paulo.
Old 3rd February 2013, 04:56 PM   #3885
Banned
Yes, a low noise, low HD FET input one. like OPA627/827 ?
Old 3rd February 2013, 05:29 PM   #3886
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
OPA132 is a nice middle ground solution also IMHO.
Old 3rd February 2013, 06:04 PM   #3887
Please be pacient with my ignorance... Does a different opamp requires changes to circuit (compensation caps or others) or can I just swap the opamp leaving the circuit unaltered?
Kind Regards,
Paulo.
Old 3rd February 2013, 06:17 PM   #3888
Banned
Tl 072 was a dual OPA, one side not used, not very elegant. So , you will have to modify the board accordingly to feat a single OPA. All OPAs have the same pin-out, but differs from single to dual.
You can chose the ones you want, as long as they are fet Inputs, and unity gain stable. Just add, on the printed circuit a compensation cap in // with the feedback resistance, that you will use, or not.
Old 3rd February 2013, 06:24 PM   #3889
You mean the 2k2 resistors? Both paralleled with caps? What value should the caps be?
Thank you
Kind Regards,
Paulo.
Old 3rd February 2013, 08:48 PM   #3890
Banned
Thank you
can-you bring me a link to the schematic ?
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
