#3861 |
If I use 2SJ201/2SK1530 instead of 2SJ162/SK1058 (different pin out) what other changes sould I do to the circuit? ![]() Has anyone thought about having a professional etched pcb and organizing a group buy? ![]() Thanks.
Kind Regards, Paulo. |
#3862 |
hi shaan do you use tone control?
#3863 |
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#3864 | |
#3865 |
Hi PauloPT
Glad you like it, enjoy.
#3866 |
diyAudio Chief Moderator
Simple rule of thumb we should remember because many datasheets don't clearly mention category by the way: Laterals are never GDS pin out. They are GSD.
#3867 |
Thank you Lazy Cat for designing this wonderful amp!
![]() I'm going to order some 2SK1058/2SJ162 to make a proper build. I have some questions about it: 1) Is it completely stable, no worries about? 2) The input filter cap is only 22pF, shouldn't it be about 10 times higher? 3) Can I use it with 4 ohms speakers? How much power would I get safely? 4) Has anyone mesured THD, just curious I'd like to know TDH at 20KHz. 5) My home made pcb's always look like something out of an horror movie. I would much prefer to have a nice professional etched pcb, is a group buy for pcb's out of the question? Sorry for so many questions...
#3868 | |
Or to do-it listening: More you filter EMI and residual distortions from previous stages, better it is. The limit is to keep the phase right at 20KHz. |
#3869 | |
Thanks.
#3870 |
Bingo !
![]() You can set-it to 750pF to let a little margin to the source impedance |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
