Simple Symetrical Amplifier - Page 386 - diyAudio
Old 26th January 2013, 06:38 PM   #3851
naf is offline naf  Indonesia
Originally Posted by shaan View Post
Bundle ten of them like dynamite sticks and join the fusewires at both ends. There you got a big and powerful 10uF dynamite... err... no, capacitor.
guitar parallel all 10, and you'll go for 10uf dc blocking cap
Old 26th January 2013, 07:10 PM   #3852
Jay is offline Jay  Indonesia
Or 2x 22uF in series, back to back. BTW, NP/BP is not always better than ordinary one. Just try any quality cap.
Old 27th January 2013, 12:24 AM   #3853
Quite a waste to use them like that ^^ better buy a big one to use
Also waste of spaces, lining them like a choo-choo-train.
Old 27th January 2013, 12:27 AM   #3854
hmm..... in series ? does electrolytic able to do that ? (in AC signal) positive or negative lead should bind together ? What NP/BP ?
Old 27th January 2013, 01:16 AM   #3855
NP=Non-Polar. BP=Bi-Polar.
Putting 2 polarized elcos make them like NP or BP.
2x22uF makes 11uF.
Can be positive to positive, or negative to negative. I don't know which arrangements suit which situations. But both can be done just like choosing NP or BP
Old 27th January 2013, 02:16 AM   #3856
i use nichicon muze bp 10uf/35 elco in mysecond stereo for my friend.
Old 27th January 2013, 05:49 AM   #3857
That's correct.
Hi, I have insert the input filter, as close to base as possible. But the slight buzzing nosie I mention earlier still exist, maybe due to lack of shielding. (it is naked PCB ^^ no casing so far)
But what I notice is that the idle current of all my BJT is lower, maybe due to elimination of inaudible oscillation. 10mA of VAS became lesser than 9mA most of the time, except VAS become very hot due to palying music loudly.
Anyway, casing for shielding should connect to safety earth or ground ? or use '1 ohm style' ?
Old 27th January 2013, 07:05 PM   #3858
shaan is offline shaan  India
shaan's Avatar
Originally Posted by guitar89 View Post
What I notice is that the idle current of all my BJT is lower, maybe due to elimination of inaudible oscillation. 10mA of VAS became lesser than 9mA most of the time.
You can decrease the 1k2 resistors in small steps to increase current through input and VAS transistors.
Small "U" shaped heatsinks will be good for VAS. Direct contact, no mica or other insulation.
Safety earth directly connected to casing. From there a 10ohm to signal ground.
PeeCeeBee V1.1 Here, V2 Here and V3 Here
Old 28th January 2013, 12:28 AM   #3859
Hehe, I have no problem with that, I could adjust the pot to adjust both sides idle current and output voltage.
But what I meant is this happen (reduction of current) without adjusting pot, I'm suggesting something happen in input line, such as reduction of HF noise.
Maybe I should put up my schematic later on after I make it nice ^^
hehe, I'm using small heatsink, but sufficiently cooled for me. The VAS doesn't goes very hot, but just makes idle current increase slightly.
Hm..... yeah, but if I doesn't remember wrongly, someone also suggest put cap parallelly to the 10 ohm.
Old 28th January 2013, 08:10 AM   #3860
shaan's Avatar
Yes. A 0.1uF cap parallel to the resistor will be good for RF suppression.
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
Copyright 1999-2017 diyAudio
