Old 25th January 2013, 01:43 AM   #3821
Originally Posted by Esperado View Post
Please, use 1K in serial and 50 or 100pf to the ground. Are your speaker's cables long ?
I prefer not to use over 1 meter cable ( I always kept below 1 meter)
Just a curious, what is the relationship of adjusting the resistance against capacitance if we kept the cutoff frequency constant ? (example: what is the difference between using 1ohm &1uF against 1k ohm & 100pF ? )
Hey Shaan, I never saw you have those links below your post (signature I believe) Its a great job putting those together and compile it, thanks you ! LC would have save alot of job if I were to see those early ! (I just have so much question to ask ^^)
Old 25th January 2013, 02:32 AM   #3822
naf is offline naf  Indonesia
Originally Posted by Lazy Cat View Post
Compared to some commercial amp? Did you like it? Which speakers?
Hi LC.. sorry for late answer
I don't have any commercial Amp, it cost to high for me and speaker i use just DIY entry level speaker.. build by local senior DIYer.
I do compare with other great design Amp i've build from this great site.
i'm very satisfied with my Shan's SSA build ... such big sound coming from small Amp, nice treble, nice bass, clear vocal... no hum, no hiss.. play all music genre vocal, instrument, pop, rock, metal, jazz
PS:
i've upgrade my VAS Tr using 1360/3423 and more smooth treble.
Old 25th January 2013, 02:36 AM   #3823
keantoken's Avatar
If you double series resistance, halve shunt capacitance. Triple resistance, divide capacitance by 3. And so on. This way LP corner will stay the same.
Old 25th January 2013, 02:51 AM   #3824
shaan is offline shaan  India
shaan's Avatar
Hi naf. Great job.
I have just finished another P3A on a 2"x3" veroboard with superfast BJTs. I haven't listened to a VFB since the SSA re-incarnation. I wonder what kind of challenge I'm gonna get with the very good and popular VFB amp P3A.
Old 25th January 2013, 02:55 AM   #3825
shaan's Avatar
Hi guitar89. Hope the links help you on your way to building your own SSA.
Old 25th January 2013, 03:02 AM   #3826
well, what I mean is that what is the difference between using those different combination ? (while we still get the same Low Pass Cutoff Frequency)
Example: combination of high resistance & low capacitance will get what result ? affect phase or anything else ?
Old 25th January 2013, 03:15 AM   #3827
shaan's Avatar
Hi guitar89. By using 1ohm/1uF instead of 1k/100pF you are going to kill your signal source brutally. With low R and high C you demand high AC current from the source. Best is to use 1k/100pF and it won't cause any sonic degradation.
Old 25th January 2013, 03:28 AM   #3828
Thanks for your explanation and advise, didn't realise it before.
Would it be wise to integrate a volume pot after these filter ? could it be put before the filter (nearer to source)? (or is there anyway to make it foolproof of putting pot)
Just curious, what if I raise more resistant and less capacitance ? example of 10k ohm and 10pF. (My guess is low source input ?)
Old 25th January 2013, 03:55 AM   #3829
shaan's Avatar
The RC lowpass filter should be as close as possible to the bases of the input BJTs, i.e. nothing between filter and SSA. This is foolproof enough.
The result is audible noise and poor frequency response, as SSA demands a low impedance source to work at its best and the 10k just adds itself up with the nominal output impedance of the source resulting into very low available drive current for an amp with 10k input impedance such as SSA, not good.
Old 25th January 2013, 04:25 AM   #3830
Ok, I will kept the minimum at front. What value of pot is recommended with this filter ? (in order not to reduce input drive current too low)
(As in my attachement ?)
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2013 diyAudio
