Simple Symetrical Amplifier
Old 22nd January 2013, 12:22 PM   #3781
Esperado is offline Esperado  France
Banned
Originally Posted by guitar89 View Post
my star ground plan is slightly different
Please, take your output ground at the star point.
Are all resistances non inductive ?
If you do not have an oscillo to see what happen exactly:
You can try to add an input filter at 200khz, can only have benefits.
If it does not solve the problem, try to add 20pf in parallel with the feedback resistances.
Old 22nd January 2013, 12:38 PM   #3782
guitar89 is offline guitar89  Malaysia
So where should my output ground takes from ? according to my layout ?
What do you mean by inductive resistance ?
I don't quite like input filter since they tends to degrade the input (more parts integrated to modify the input) , but I will give it a try. So it is -3db at 200khz ?
Ohhh yeah, never though of that idea. Anyway, does adding that cap parallel to feedback resistor have any drawbacks ? Will try it tmrw !
Old 22nd January 2013, 12:57 PM   #3783
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
I would not try this, since CFB resistors paralleled with cap usually cause immediate oscillations. More you'll gain with correct Cdom.
Old 22nd January 2013, 01:11 PM   #3784
Ok, get it. So VFB won't be affected by this ? Still couldn't understand why CFB resistor would trigger oscillation, maybe its why I couldn't precisely understand how CFB works
Old 22nd January 2013, 01:21 PM   #3785
Banned
On my amp, at those values (10/20pf), it just dump the little overshoot on square waves. Don't you had some pf on you own boards, that you adjust with a variable cap ?
guitar89: inductive resistances are wired-wound power ones (to be avoided).
Your output grounds has to be taken on each IC board, where the power ground goes-in.
Old 22nd January 2013, 01:31 PM   #3786
Banned
VFB returns the output signal to an inverting device (the differential -input) to be compared with the original signal.
CFB return the output signal to the same input device used for signal. The signal is amplified in an common emitter cofiguration, while the feedback signal is entered in a common base configuration. So, the same input device is used to compare both.
As common base is low impedance, that's why it is called 'Current" feedback.
Old 22nd January 2013, 01:38 PM   #3787
Lazy Cat's Avatar
Always Cdom only, never have had any cap on current feedback resistors. Can try it by VSSA at squares loaded with capacitor, to compensate ringing.
Old 22nd January 2013, 01:49 PM   #3788
homemodder is offline homemodder  Portugal
Cdom is the worst compensation one can use on a CFB circuit, severly limits bandwith and the vas linearity (also causes imbalanced currents to flow through the two vas transistors and limits PSRR ) its much better using shunt compensation in combination with a little compensation accross the feedback resistor.
Old 22nd January 2013, 01:54 PM   #3789
MiiB is offline MiiB  Denmark
how to implement shunt compensation..???
Old 22nd January 2013, 02:25 PM   #3790
Lazy Cat's Avatar
It is unconditionaly stable with Cdom=12 pF only, squares response is perfect. If you know more, you have to support your claimes with explanations. Criticism is easy in any form.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
