#3731 | |
The level of error signal is so low at audio frequencies that slew rate of the error will be negligible comparing the the ones of the OPA and Power amp itself. (both 1000V/µs) Last edited by Esperado; 4th January 2013 at 06:16 PM. |
#3732 |
I read a previous post incorrectly. I have nothing to add. Keep up the interesting work!
#3733 |
ugh.... technospeak, technospeak and more technospeak. could someone please translate all of this in to sound quality of this design? i'm not getting much out of this thread or the one about fetzilla, i think... this foreign language is making my head hurt and me forget stuff now.
i was getting a little but of something when someone talked about speed, detail and bandwidth, but alas it was only theoretical talk and not a review of this design SQ. just looking for a non technical lowdown to see if maybe i try buidling one of these instead of maybe a gainclone or get a trends or even kingrex class D. i'd like a fast and detailed amp that isn't lifeless or syrupy thick either. Last edited by budget minded; 17th January 2013 at 06:53 AM. |
#3734 |
I think both one of the SSA options or the fetzilla would be very much the kind of sound you are looking for. Hopefully and SSA kit will be coming up soon ? ? ?
Any news on that Lazy Cat ?
. . . . . . . . . . . . . . . . oOo . . . . . . . . . . . . . . . . . . Best to assume that everything makes a difference |
#3735 |
i build ssa shaan version and it sound very good. worth to build.
#3736 |
what's up with all the talk i keep seeing about tweaking bias etc. after the amp is built? i'd rather just get a kit that you build and be done with it with adequate instructions for someone whose never done anything more ambitious than solder speaker cables that thinks he could confidently build a speaker crossover as long as no resistors (have to be installed directionally, right?) are needed.
i was originally interested in DIY amps because of simple gainclones with just 9 parts. when i start seeing pics by people i'm guessing are more experienced than me asking if they mounted everything right, memories of my NAD blowing up when my subwoofer wires shorted come back. *pop pop pop*! flash and oh all that smoke all the other talk about making changes to power rails and filtering too make me think this might be too big a project to attempt for me. my mind is allergic to abstractions. i understand mechanics much better as you can see what's going on. Last edited by budget minded; 17th January 2013 at 09:46 PM. |
#3737 |
Shaan tried SSA with servo, PCB is at post #3428, so no adjustments, I think it's easy for beginners to build. I'm not sure anybody made it yet.
#3738 | |
You will feel as comfortable as being at home.
All the best, Max.
#3739 |
I think from what he says budget minded would prefer assembled & tested boards to which he can add a PSU & box etc - not sure what to recommend for this.
#3740 |
I would recommend an Hypex Nc400 with its dedicated power supply.
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
