Simple Symetrical Amplifier
Old 3rd January 2013, 08:13 AM   #3721
Esperado is offline Esperado  France
Banned
Happy New year to you L.C. I hope this year will be full of splendid AUDIO projects as your SSA was.
I wanted to make a sim with your version of SSA, and asked your sim file for that. But my message had no answer. Anyway, this exploration is not a surprise for you, if you had read your private message box recently :-)
Old 3rd January 2013, 07:52 PM   #3722
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Hi Esperado
OP amp kind of error correction is actually working as OLG of the corrected amp would be much higher, it certainly can lower distortions if stability maintain unaffected. Most probably OP amp will drive the feedback signals into peaking and even into oscillations if original amp could not follow.
What VSSA in other thread surprisingly showed me is its enormous damping (extremely low Zout) gained from high OLG/bandwidth and exact feedback/compensation scheme. uV feedback precision coming out of six transistors only makes amplifier's output differentiating from unloaded conditions down to few mV.
Square waves misuse showed no instability and for me that is of more importance than mostly accepted low THD/TIMD.
Regards, Andrej
Old 3rd January 2013, 08:46 PM   #3723
Banned
Yes it increase the ratio of feedback as much as you can afford keeping the stability. (Phase margin can be unchanged, and even, we can be increased with some compensation caps in the error feedback loop, without affecting slew-rate of the power amp itself.).
About speed, the problem with fast power amp is to find an OPA fast enough, as SSA is damn fast itself. . No risk, in my example, to saturate the OPAs, the output of the second OPA stay at <+/-700mv peak at 100Khz full power with distortion at -60dB.
I do not know if it improve the sound or not: Need a try in real world. May-be the benefit will be side of the damping factor ?
As it is simple, easy and not expensive nor destructive, it deserve a try.
Old 3rd January 2013, 09:47 PM   #3724
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I think this idea is pretty cool. I would love to see a real world implementation.
Old 4th January 2013, 01:04 PM   #3725
keantoken is offline keantoken  United States
keantoken's Avatar
I think a more effective way of reducing distortion would be to use drivers for the LFETs.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 4th January 2013, 01:38 PM   #3726
Banned
I think reducing distortion of the open loop of an amp is not to be opposed to the use of feedback, they are complementary. if you can reduce closed loop distortion while keeping the slewrate with a driver (i doubt) the error correction add will reduce the new distortion with the same 10 ratio.
Old 4th January 2013, 02:26 PM   #3727
keantoken's Avatar
So the point is to decrease distortion without impairing slew rate?
Old 4th January 2013, 02:31 PM   #3728
Bonsai is offline Bonsai  Europe
Very nice Esperado :-)
I am working on a new amp (100W CFA) and after this will do another amp with AFEC (switchable!). I think the technique has merit, but of course you have to take care with the loop compensation. The free DC offset control is also a great side benefit!
Old 4th January 2013, 03:41 PM   #3729
Banned
Well, something is interesting, below your question.
Because we increase the error feedback level, in a way, we reduce the slew-rate/correction-signal ratio.
But, because we are dealing with a yet low distortion, and because we can filter extreme HF from this added part of feedback; i believe we do not have to fear any added TIM.
So, the main benefit is to improve distortion on an EXISTING amp without modification of the amp Itself.
As noticed by L.C. an other approach is to increase OLG of the amp, not so easy while keeping-it stable.
This error correction present, of course, some negative aspects: it is a little acrobatic and need precise fine tuning.
Even if i had this idea long time before, while i was working to my protection system, i forgot-it with time and it was YOUR publication which refreshed-it in my mind. So all the credit is for you.
Old 4th January 2013, 03:57 PM   #3730
keantoken's Avatar
But you are not filtering extreme signals from the opamp. Any input/feedback signal regardless of BW will enter the opamp's output, no? Does the simulator model the effects of opamp output impedance?
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
