Simple Symetrical Amplifier - Page 368 - diyAudio
Old 7th December 2012, 07:59 AM   #3671
naf is offline naf  Indonesia
Originally Posted by shaan View Post
My local DIY friend Bhaskar has printed six SSA boards. Yesterday I was on a visit to his home and had some unique experiences.
First, he's a genuine music-lover; has over 3000 pieces of gramophone records and most of them are pure gem recordings. Many dating to 65's! I had my first experience of listening to analog recording and I was completely blown away. The realistic feeling of the music just froze me and now I know why people say that once you get into analog, there's no coming back.
Second, he is a very kind person. He provided me with two of the six SSA boards made and now I have my own designed peeceebee at hand.
The peceebees look very well etched without any errors.
Now I'm on the way to build a pair of SSAs in the pro way LOL.
Thanks for the good wishes all.
Wow.. nice peeceebe finally you have your own board
Old 7th December 2012, 10:47 AM   #3672
Magna is offline Magna  India
Nice PCB shaan...I could see your resistor CCS. I'm also revising a few changes with my SSA to take up resistor CCS, i'll let you know my results soon.
Old 7th December 2012, 08:57 PM   #3673
shaan is offline shaan  India
shaan's Avatar
And here it is. Running smoothly.
Offset setting was pretty easy; within +-5mV.
Bias perfect with 3mA, 14mA and 160mA in input, VAS and FET respectively. Without any manual setting. The input BJTs are BC550C and BC559C.
Sounds just like an SSA.
Hmm... peeceebee works for me too...
PeeCeeBee V1.1 PDFs, V2 PDFs,V2 Gerbers,V3 PDFs,V3 Gerbers
Old 8th December 2012, 09:47 AM   #3674
Lazy Cat's Avatar
Exclamation Magna's SSA HP for PA
Originally Posted by Magna View Post
Hi LC,
Thanks LC. Its my pleasure, to have your comments on the scheme....i'm sure that will certainly improve the performance of the amp further.
Hi Magna
Comments as I promised:
- Q3, Q5 must be firmly thermally coupled, glued or grease + wraps
- input CCS-s should be top quality with thermally independent reference as in #post 3034. Replace Q8, Q11, Q12, Q13 with reference CCS-s
- C7, C62 lower to 100 uF
- C10, C34 remove these 47 pF caps, install trimmer-caps and find optimal sweet spot between lower and higher freq oscillation
- C16, C18 higher to 1000 uF
- optimally and effectively front-end should have 5 V higher rails than output stage
- C1 should be 10 uF, C5 100 pF
- D1, D13 recommend to change to 1N4732 - 4,7 V
You can fill in the whole 5 output pairs on PCB for 2 ohm loads capability.
Looking forward to see your modifications and reports.
Old 8th December 2012, 09:54 AM   #3675
Lazy Cat's Avatar
Exclamation SSA basic principle topology
For low harmonic distortion CCS-s must have superb HF modulation suppression at least -100 dB according to nominal source/sink current.
Input BJT-s must be firmly thermally coupled.
Old 8th December 2012, 05:53 PM   #3676
Banned
No good enough npn-pnp matched pairs available ?
Old 8th December 2012, 08:50 PM   #3677
sonnya is offline sonnya  Denmark
sonnya's Avatar
They are typically about 100 In gain. And gain is typ. Very unlinear.
But you could choose bc847bpn, but they cannot handle the power.
Old 8th December 2012, 08:58 PM   #3678
Banned
I don't understand the politic of the manufacturers. They all offer the same products under hundred of references, like in supermarkets, and misses the most useful quality products.
Hundred of white sugar packages, all the same, and hard to find brown cane.
More depressing, when you find something you really enjoy and use everywhere, it don't last: "osolete" !
Old 8th December 2012, 09:01 PM   #3679
sonnya's Avatar
i totally agree!!!
Old 8th December 2012, 11:42 PM   #3680
Jay is offline Jay  Indonesia
No politics, only economy.
If they sell brown cane, will they get more profit because brown cane is better than white sugar?
How much of us need the matching properties of PNP and NPN? How much is our purchase in a year?
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright 1999-2017 diyAudio
