#3661 |
Hi jay,
What would be the "ideal" bias? About 17ma current flows across the resistor with the current setup(+/-75v)....Is it too high? Shaan, Thanks for the kind words. I've chosen keltron caps for most locations except for the main decoupling caps. In my experience these caps are much better than the regular samwa types, known for leakage at its early life span. Of course these caps cost atleast twice more than samwa here in the local market. Everything worked to my expectation, except the dc offset, which goes up / down (+ / - 50mv). Once i get this sorted out, planning to test the amp in a PA system to explore further on this amp. will post my results soon... |
#3662 | |
I think there is nothing wrong with "hot" regulator (as long as there is sufficient heatsinking). I don't know about the "optimum" bias for the input. I have used around 10-12mA. ADD: May be Shaan has a comment regarding this regulator (CCS). I think he didn't use it at the end. Last edited by Jay; 4th December 2012 at 09:31 AM. |
#3663 | |
Regards L.C.
#3664 |
Hi jay,
Thanks for your suggestions. yes, the circuit is based on shaan's version, except the CCS which i intend to keep to improve PSSR. I'll try to modify the bias to 10 - 12 ma and see if it affects the sound. I'd like to keep the sound as it is.... Hi LC, Its the same circuit as shown in the post 3550.... |
#3665 | |
![]() If you like I can comment your sch later today. Otherwise very professional SSA you have made.
#3666 | ||||||
Also the schematic shows no 10K from the conjoined bases of the input pair to ground. This could also cause offset problems due to lack of base current at the inputs. Quote:
![]() Quote:
It's based on LC's SSA as the VAS has cascodes. My PS is +-28VDC, so cascodes there is a no-no. But, maybe in future, with +-56V... We'll see.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA Last edited by shaan; 4th December 2012 at 11:10 AM. |
#3667 |
Hi LC,
Thanks LC. Its my pleasure, to have your comments on the scheme....i'm sure that will certainly improve the performance of the amp further. Hi Shaan, I'll take your views on bias....i'll try to couple all the input trannies with heatsink compound....perhaps that could solve the DC drift problem....i do have the 10k input bias resistor in place with this amp How do i reference the CCS to ground with this design....any idea? Will that have positive influence on the overall sound quality of the amp...? I'm already very happy with the sound.... Do you think a simple resistor bias is better than the CCS, especially the PSRR and of course sound quality as well...what's your experience...? probably i'll also experiement with that.... |
#3668 | |||
![]() Quote:
It's easy to understand that CCS will improve the precision of the feedback network at HF by an order of magnitude than that with a resistor. Probably the PSRR will also be higher with CCS. but, BUT what if your brother or friend likes the "precise" sound but you don't??? If you like the sound and it doesn't give you fatigue then no matter whether its a CCS or a resistor, it's perfect. Well, my SSA's FB network is fed through two 1K2 resistors and this amp sounds more precise to my ears than any other amp I have heard, right up to full volume. It has stunned more than 100 people with its sound(me included) to-date and is keeping up the shock-job for new people almost every week. No hum no noise no no instability no fatigue so far. My SSA is made for music, and its music says it's true. That said, there is no guarantee that you will like the resistor-fed SSA sound more than the CCA-fed SSA. Here's the devil, subjective quality, totally private property.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#3669 |
Hi Shaan,
Lots of ideas for further experiementation on CCS....Thanks. Will let you know about my results without CCS...As you've pointed i may / may not like the sound.... |
#3670 |
My local DIY friend Bhaskar has printed six SSA boards. Yesterday I was on a visit to his home and had some unique experiences.
First, he's a genuine music-lover; has over 3000 pieces of gramophone records and most of them are pure gem recordings. Many dating to 65's! I had my first experience of listening to analog recording and I was completely blown away. The realistic feeling of the music just froze me and now I know why people say that once you get into analog, there's no coming back. Second, he is a very kind person. He provided me with two of the six SSA boards made and now I have my own designed peeceebee at hand. ![]() The peceebees look very well etched without any errors. Now I'm on the way to build a pair of SSAs in the pro way LOL. Thanks for the good wishes all.
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
