Simple Symetrical Amplifier
Old 12th November 2012, 01:30 AM   #3651
Jay is offline Jay  Indonesia
Banned
Originally Posted by Esperado View Post
I'm bored with their stupid interface...
Programmers may see it from different perspective. As long as it has the tool to construct more functionality, it is a good engine.
You can use variables (parameters in LTSpice) and make general statements (and components) made from variables so the only thing you do when you want to do different function (e.g. analysis) you just right click on a set of statements, make them a "comment" and right click on another set and make them "SPICE Directive". All of these statements (and components) can be put on the top of the circuit such that when you create a new circuit, you just copy them using F6 and drag.
Just an idea/perspective.
Old 12th November 2012, 02:09 AM   #3652
keantoken is offline keantoken  United States
keantoken's Avatar
I like that idea Jay.
Consider math programs. You have to know some sort of console interface/language. It is just too difficult to design a graphical interface that is more intuitive than a written equation. You cannot replace an equation with a bunch of buttons and sliders, and retain the flexibility of written math.
Some extra features would make LTSpice less tedious for sure. However if you really get deep into optimized design, you are going to end up designing your own functions anyways. Someone who uses all the advanced features of SPICE probably will not have such a need for a heavily scripted interface. People who expect to only use the graphical parts of LTSpice and still want the full functionality of simulation will find the program lacking. The program was most likely intended for people who already know their way around SPICE.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 14th November 2012, 07:48 AM   #3653
ivanlukic is offline ivanlukic  Serbia
Does anybody use TINA-TI simulator available at Texas site? If yes, can you send some comments?
Old 14th November 2012, 08:00 AM   #3654
ashok is offline ashok
ashok's Avatar
Originally Posted by Lazy Cat View Post
......CSA prototype functional at last.......
So how does it sound ? Compared with, for example, the schematic Nico used or any other commercial amp we know of.
This has become a really long and interesting thread !
AM
Old 14th November 2012, 09:10 AM   #3655
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Hi ashok
As you can notice from the pics this is testing assembly with thin alu plate to thermally connect all driver output transistors and NTC sensor. The plate has GND potential and serves to electrically/thermally simulate the heatsink and still to enable enough space to make all necessary testing evaluations easier, like to set compensation caps, minor parts value modifications etc.
Thermal capacity of the plate is zero, so all the power measurements and sound checks can be done later in the process when regular heatsink will be here. It is ordered, just waiting to be delivered and than I'll report about SSA CSA comparisons etc.
Old 14th November 2012, 09:46 AM   #3656
ashok's Avatar
Thanks for that update. Yes getting it all fixed for listening can't be done without enough heatsinking .......and spare time !
Your hands seem to be full with numerous versions to try out. Must be quite exciting ! Great job.
Cheers.
AM
Old 27th November 2012, 10:29 PM   #3657
Lazy Cat's Avatar
Before big heatsinks for CSA arrives I am actually not just waiting, for instance today I assembled real plate PCB to the case plate and installed all connectors, LEDs and remote/local trigger switch. Pictures says it all.
Old 3rd December 2012, 06:59 PM   #3658
Magna is offline Magna  India
Hi all,
After a month's work, finally got my version of SSA singing...
It work's on +/- 65V with 3 pairs of Fet's. The Amp remains silent at switch on, no thump / noise. couldn't hear any hum / noise with my ears right on to the speakers , and now who said PSRR is not good with SSA....
And the sound....huge difference from my previous setup. Anyone who could hear the difference between a 5534 and opa134 opamp should be able to appreciate it.
Couple of observations....
I've adjusted the trimpot for near zero DC offset, after an hour with music at high volume the dc drifted from 3mv to about 45mv. Then i switched it off and on after a few minutes, and measured about 20mv. Is this normal...?
Also the resistor (3k3) that feeds from the base of driver cascode to base of input cascode does get uncomfortably hot to touch. My simulation shows little more than 1w of dissipation at @ +/- 75v. will Reducing the dissipation by increasing its value affect sound quality?
Everything else seems to work perfect...
Old 3rd December 2012, 07:10 PM   #3659
shaan is offline shaan  India
shaan's Avatar
BRAVO BRAVO BRAVO!
Nice DIY Manga! You deserve the SSA sound, and now you have it, enjoy.
edit: Good choice of capacitors brand.
V4 GB! | V4H GB!! | PSU GB!!!
Old 3rd December 2012, 07:34 PM   #3660
Banned
I think the input bias was specified for 10mA? With 10mA a 3K3 will dissipate 330mW.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
