Old 11th November 2012, 07:09 PM   #3641
Joachim Gerhard's Avatar
Klippel is working on a model for 40years. I think his latest model has 100 plus components.
This is just a basic overview :http://www.klippel.de/fileadmin/klip...ity_Poster.pdf
Why not connect a speaker while measuring ? OK; it gets pretty nasty loud.
Old 11th November 2012, 07:45 PM   #3642
shaan is offline shaan  India
shaan's Avatar
Originally Posted by Esperado View Post
I do not understand why they do not provide an easy square waves generator, where you set the frequency, the level, and the offset... and, by default potentiometers, trasfos, and some other very ordinary parts we use all the time.
Hi Christophe.
Simetrix is the answer. I use it to sim everything from solid state relay to resonant ZVS flyback converter to SSA.
It has an easy square/sine/saw/triangle/pulse generator with offset/delay and other parameters. Also a bidirectional pulse generator, potentiometers, electrolytic caps, inductors and transformers. All with settable parameters and a very easy interface.
Old 11th November 2012, 08:46 PM   #3643
Esperado's Avatar
Originally Posted by shaan View Post
Hi Christophe.
Thanks a lot, Shaan, i will try this.
BTW; interesting sims, may-be ?
My amp CFB vs VFB. The two sims are from the upper input VAS stage.
Don't compare the two low and high ends frequencies, the CFB is bandwidth limited for production, while VFB tuned to explore extremes.
Christophe.
Ultimate Protection
Old 11th November 2012, 09:12 PM   #3644
keantoken's Avatar
The graphs are difficult to compare because the scales are not synchronized.
Both CFB and VFB depend heavily on implementation. I'm not sure what part of the circuit these traces are from but I would guess the input stage for the VFB version has much higher transconductance necessitating more compensation to load it down enough at RF to stabilize it.
If the traces are taken from the VAS input, then the rail voltage variations will be added to the signal, obscuring the actual behavior of that node. Unless you used perfect voltage sources for the supply.
Old 11th November 2012, 09:25 PM   #3645
Lazy Cat's Avatar
CSA prototype functional at last. Today I installed output BJTs, so the output BIGBTs are finally completed. Closed loop stability compensation scheme without any change as expected, output bias tested up to 0,5 A, DC offset +/-10 mV, very stable output. Sine waves from generator OK, 100 kHz square waves OK. The only thing left to finalize is temperature compensation for the main heatsink, 10 k NTC used as temperature sensor (pic), only 15 pF from NTC to housing (case GND) means also from VAS output to GND.
CSA's next stage is to finish the second channel and housing with heatsinks, toroids, etc.
Old 11th November 2012, 09:39 PM   #3646
lanchile's Avatar
What and why are those wire soldered to the fuses?
Old 11th November 2012, 09:44 PM   #3647
Lazy Cat's Avatar
hehe in testing phase instead of a real fuses, blown ones takes their place. Those wires connects 25 ohm/20 W resistor on both rails to prevent any outputs damage when closed loop stability is calibrating to optimal local feedback C. I use trimmer C on both VAS sides to find optimal capacitance. In CSA they're around 10 pF.
Old 11th November 2012, 09:50 PM   #3648
Lazy Cat's Avatar
Two C trimmers for compensation on pic. When settled to optimal value, they're replaced with fixed ones.
Old 11th November 2012, 10:20 PM   #3649
Esperado's Avatar
L.C ? Did you have time to provide the differential input SSA sim file ?
Christophe.
Ultimate Protection
Old 11th November 2012, 10:40 PM   #3650
Esperado's Avatar
Look at the phases sens and what happens around 1Khz. This does not change whatever the current values.
Christophe.
Ultimate Protection
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2013 diyAudio
