Simple Symetrical Amplifier
Old 25th October 2012, 01:34 AM   #3571
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Jay View Post
The tweeter uses some kind of material (still a dome) which is named, if I'm not mistaken, SELENIUM. Seems like a metal, but soft like fabric. This dome material is popular in PA speaker system.
Maybe your HF driver uses a Mylar diaphragm?
Old 25th October 2012, 06:27 AM   #3572
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Originally Posted by naf View Post
dear Salas and Shaan,
channel 1 done, current feed change by paralelling 3k3 || 2k4.. Vas current down to 14.2mA
Hi Naf,
[edit] Can you show it in the schematic? I may get hold of my 25vac transformer this coming weekend, and of course it will be close to +/-32vdc.
TY!
Old 25th October 2012, 06:40 AM   #3573
naf is offline naf  Indonesia
Originally Posted by abetir View Post
Hi Naf,
can you show it the schematic? I may get hold of my 25vac transformer this coming weekend, and of course it will also be a +/-32vdc.
TY!
this is my change 1k2 to 1k4 by paralelling 2k4 with 3k3
r 220 increased to 267 by series 220 + 47
Old 25th October 2012, 11:04 PM   #3574
de Ocampo's Avatar
thanks naf, will try that too, if i encounter the same abnormal heating of parts.
Old 28th October 2012, 03:54 PM   #3575
Jay is offline Jay  Indonesia
Banned
i'm not sure. it must be a common thing. color is yellowish.
Old 30th October 2012, 01:47 AM   #3576
Esperado is offline Esperado  France
Banned
Just a question. Did someone have measured the common mode rejection of his SSA ?
Old 30th October 2012, 03:46 PM   #3577
shaan is offline shaan  India
shaan's Avatar
Interesting, I am eager to know the CMRR too. But how to inject a phase-equal signal into the low-impedance inverting input(s)? Or is there other ways to check the cmrr?
V4 GB! | V4H GB!! | PSU GB!!!
Old 31st October 2012, 11:03 AM   #3578
Banned
Adding an offset to the input signal DC coupled, signal = 1/2 max level, offset = +1/V or -1/2V. That way, the signal will go from 0V to + (or - ) V.
We are not interested, here, with the rejection itself, but the distortion induced by asymmetrical signals.
Of course, we need a cap in the output before to measure the distortion. Then compare distortion with offset vs distortion without.
Old 2nd November 2012, 07:28 PM   #3579
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Originally Posted by MiiB View Post
I have made some different outputs. from laterals to Bipolars and a combination of both.
Hi Michael, I wonder which o/p device combination you preferred in the end ? In spice I found irf610/9610 followed by BJT looks best but for a low power amp a BC546c followed by a lateral MF also works very well - this is what I'm using at present but I will upscale soon.
Sound is very very good. I believe its the simplicity and short current feed-back path that plays a major role in this. Like less is a lot more. The SSA is for sure a strong concept. But it really does require some good housekeeping. This type of simple current feedback circuits benefits a lot from fixed working conditions. Simple voltage/resistor biasing is not good enough for current feedback, as the feedback currents will alter/modulate the working conditions . The current feed-back needs to be purely additive process, for this you need a good high impedance CCS driving the circuit.
Do you think a fixed resistor from a perfect supply would still spoil the FB operation ? In spice I see little difference . . . or do you also think the high impedance of a good CCS contributes to ideal working conditions ?
mike
Old 2nd November 2012, 08:01 PM   #3580
MiiB is offline MiiB  Denmark
The fixed resistor sets the working (driving) current flow in the input pair... when you inject the current from the feed back it will add to the driving current. if the current source is ideal the process will be purely additive and precise, but a 1k Ohm current source (the resistor)..is hardly ideal and so the feed back process is unlinear with amplitude. in steady state (sines) (spice) this effect will not be visible in terms of higher distortion, but in dynamic conditions with ever changing amplitude this effect is easy to understand.
Listening vise you get an amplifier with better focus and a stable character.. when inserting a CCS.
My SSA has changed quite a bit now i set the VAS current through mirrors and use Hawksford cascodes on both input and VAS.
My output is a combination of Fets and Bjts...
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
