Simple Symetrical Amplifier
Old 18th October 2012, 09:54 AM   #3471
naf is offline naf  Indonesia
thank you Sir Esperado,
in my first draw i like to connect pin 3 to ground.
and then i read maxim app-notes in their note is not good to connect pin 3 to ground... here they say
"These two circuits are the most common mistake made when terminating an uncommitted op amp. They are equally bad because the op amp's output will be railed low, causing the op amp to consume more supply current."
and here the link Avoiding Noise and Power Problems with Unused Op Amps - Application Note - Maxim
Old 18th October 2012, 10:18 AM   #3472
Esperado is offline Esperado  France
Banned
Hi, naf.
"If the circuit has dual supplies, ▒3V for example, the two resistors are not necessary and simply grounding the non-inverting terminal is sufficient."
The non inverting pin will be at 0V, and because Gain factor= 1 the out, then the inverting pin will be at the same potential. No problem.
And some opamp does not like their input to be at the rail potential, as the can invert their output in that situation.
Old 18th October 2012, 05:11 PM   #3473
Originally Posted by Esperado View Post
Hi, naf.
Thank you very much for your explanation Sir.
Actually i did search howto proper termination of unused opamp pin after reading your alert to Shaan SSA Servo.
Old 18th October 2012, 05:11 PM   #3474
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
:-) But i can't imagine that. Acoustic coupling between 2 speakers can lead to 0db output up to +6db at low frequencies comparing to one. (3db average)...
Chrisophe,
I was only thinking of the possibility, but the transducers (speakers) are operated at DC pulses at the sample rate of 44.1kHz. There is no analog involved it is purely digital. The transducers need be quite small and light and a very fast, but I am sure this is possible. A Guy like MiiB would need to say if he can make such a transducer.
As you say 2 speakers would give you +6 dB more than 1 speaker; 16 speakers moving forward would give you +96 dB higher SPL and 24 speakers moving forward would give +144 dB higher SPL.
This follows the digital value faithfully. Besides there should be no distortion either and of course no feedback, it is a a pure digital system and will generate very little heat and whatever the supply could deliver would be passed to the transducers.
Kindest regards
Nico
Old 18th October 2012, 07:19 PM   #3475
Banned
I don't said that. It is true only if the acoustic wave length is large enough that you can consider distance between speakers as 0. So this is true only at low frequencies. I said the average level increase is 3dB, doubling loudspeakers. Very well known by PA managers :-(
In a way, logical: it double the power, not the level.
Old 18th October 2012, 07:26 PM   #3476
R.I.P.
...............As you say 2 speakers would give you +6 dB more than 1 speaker; 16 speakers moving forward would give you +96 dB higher SPL and 24 speakers moving forward would give +144 dB higher SPL. ............
I don't know who said this but they are wrong.
If one speaker with One unit of power gives a relative output level of +0dB,
then 2speakers with 2units of power get to +6dB
4spkr & 4p get to +12dB
8spkr & 8p get to +18dB
16spkr & 16p get to +24dB, NOT +96dB.
If the group of 16speakers were fed with the same One unit of power, then the relative output level would be +12dB.
But, as usual with an array of speakers, one must consider over what frequency range that extra sensitivity is available.
regards Andrew T.
Old 18th October 2012, 07:37 PM   #3477
Nico Ras's Avatar
Not true, each speaker would undergo a cone movement that would be equivalent to say the supply of 5V dc being applied to the transducer for one period of 22uS. I think this is worth investigating if someone already has please tell me.
Kindest regards
Nico
Old 18th October 2012, 08:46 PM   #3478
Jay is offline Jay  Indonesia
Banned
Noooo.... transducer technology is light years away from that. Unless low-fi is acceptable then yes it is possible even today
Old 18th October 2012, 09:02 PM   #3479
Banned
Did-you forget the inertia of the cone ?
And remember, if you send a high level 22Ás pulse in-it, you will get awfull cone fractioning effects (distortion, etc...).
More than that, if you change the emitting surface at each level step, you will change the dynamic response curve a very strange way.
Old 18th October 2012, 09:13 PM   #3480
Banned
But i think, Nico, that your idea can take some sens if we imagine some compression driver adding 16 motors (bits) in one horn. Because source will stay concentric and same emitting surface whatever the level. And 6db gain here, yes, if the units are at the same distance from the throat.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
