Simple Symetrical Amplifier - Page 344 - diyAudio
Old 15th October 2012, 06:52 AM   #3431
naf is offline naf  Indonesia
Originally Posted by shaan View Post
Hi naf.
The only problem I think is when one doesn't know the pin alignments of the TO126 package, which happened in your case too. That is why I pointed the "E C B" to each of them. Knowing the pins of the BJTs is a basic requirement and I think if one places the transistors following the E C B as situated in the silkscreen then all will be well.
The rectangular symbol is for TO220 not TO126 coz my stupid PCB software don't have it. The picture is just to show what the final think will look like. I will remove the rectangles in the final version(which I am going to build myself too).
Thanks you, Shaan
does this servo version have been tested and Ok?
Old 15th October 2012, 07:20 AM   #3432
shaan is offline shaan  India
shaan's Avatar
So far okay in sim only. I am currently soldering the IC and the others parts and will connect them hanging over my SSA. I am going to order a bunch of the servo peeceebee within a week or two.
PeeCeeBee V1.1 PDFs, V2 PDFs,V2 Gerbers,V3 PDFs,V3 Gerbers
Old 15th October 2012, 07:25 AM   #3433
I'm waiting your result... and preparing my iron .
Glad to hear that you will order a bunch of the servo peeceebe
Old 15th October 2012, 08:10 AM   #3434
Hi naf.
hai shaan howare today....very nice your layout ssa pcb
Old 15th October 2012, 08:19 AM   #3435
shaan's Avatar
Default Everybody knows that it would work...
Test done. Offset +/-2mV. Opamp fed directly from Zeners(I know this is not good, that's why there will be cap-multipliers in the servo peeceebee ).
Cheers!
shaan
p.s.- my veroboard SSA has become super ugly. Sorry for the bad looks!
edit:- 1. no sonic/bias change, 2. the pots are disconnected from the inputs.
Old 15th October 2012, 03:42 PM   #3436
Banned
Please comment...
May-be it would be carefull to short circuit the unused outout OpAmp with its - input and + input to ground ?
Old 15th October 2012, 06:47 PM   #3437
shaan's Avatar
Hi Christophe.
Yes I can do it.
Would you please explain the advantage? I don't know what bad would happen if the unused channel is left floating?
Thanks.
Old 15th October 2012, 08:15 PM   #3438
Banned
Hi Christophe.
Yes I can do it.
With no feedback, the OP Amp has terrific full gain (noise) and can oscillate With negative effects, both by capacitive coupling with the other one and its power supply rails. Just plug your oscillo to the unused output pin as it is...
.Did-you imagine to let your power amp with no feedback ? It is the same.
Old 15th October 2012, 09:27 PM   #3439
apassgear's Avatar
This is my plan. Please comment...
Hi Shaan,
Can you please point to the schematic corresponding to your last art work?
BTW, very nice layout.
Tony
Old 15th October 2012, 11:54 PM   #3440
shaan's Avatar
Thanks a TON for the explanation!
Unused inputs shorted to ground.
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2017 diyAudio
