Simple Symetrical Amplifier
Old 12th October 2012, 02:05 PM   #3421
ashok is offline ashok
ashok's Avatar
Originally Posted by boyet0173 View Post
Hi abetir,
What paper did you use to transfer the toner in the pcb?
Boyet
Ideally ( some) people use printer photo paper . But there are several types and you should be sure you are printing on the correct side. Some low cost photo paper works very well.
Next best inexpensive option is shiny paper used to print leaflets for products/promotional brochures and glossy magazine pages. The paper should not be too thin.
You will need to test the paper. If it works well and comes from a glossy magazine then reserve it for all your pcb printing needs !
Paper should be typically 70 to 80 gsm ( like most paper used for normal printing).
Nothing is cast in stone. Try out what ever is available. Something will work !
AM
Old 12th October 2012, 09:20 PM   #3422
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Originally Posted by abetir View Post
Perfect DIY...well almost...
Nothing stops you to assemble on the copper side, it will work as well and anybody looking inside your box would think it is double sided.
Kindest regards
Nico
Old 12th October 2012, 10:13 PM   #3423
shaan is offline shaan  India
shaan's Avatar
Yeah!
That's true!
V4 GB! | V4H GB!! | PSU GB!!!
Old 12th October 2012, 11:13 PM   #3424
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Old 13th October 2012, 01:15 PM   #3425
Esperado is offline Esperado  France
Banned
Do anybody thoughts deeply change the way sounds your system ?
Old 15th October 2012, 03:18 AM   #3426
boyet0173 is offline boyet0173  Philippines
..pretty close Shaan..
It's actually an A4 copy paper wrap.
boyet,
I was told the A4 size stickers being sold at National Bookstore is ideal for use on toner transfer method (you won't be needing the sticker of course just take the "backing paper"), better yet check on the "Staples" brand. I dunno' if you can find the "wrapper" that I've used, it was actually for office use, but I guess any glossy type paper that can tolerate heat without peeling off, should be good enough for the job.
In laserjet toner transfer method, "practice makes perfect"
Hi abetir,
Thank you for the info. I will checked on the National Bookstore your recommendation. Thanks Again.
Boyet
Old 15th October 2012, 03:23 AM   #3427
Hi ashok,
Thank you for answering my query.
Boyet
Old 15th October 2012, 05:01 AM   #3428
shaan's Avatar
Default SSA with servo...
This is my plan. Please comment...
Old 15th October 2012, 06:30 AM   #3429
naf is offline naf  Indonesia
Shaan, please fix bd 139/140 silkscreen component (rectangular symbol for metal surface) , for skilled builder this is easy but for newbie like me this will make hell...this happen to me. Wrong ECB pin just by following bd139/140 silkscreen component
Old 15th October 2012, 06:42 AM   #3430
shaan's Avatar
Hi naf.
The only problem I think is when one doesn't know the pin alignments of the TO126 package, which happened in your case too. That is why I pointed the "E C B" to each of them. Knowing the pins of the BJTs is a basic requirement and I think if one places the transistors following the E C B as situated in the silkscreen then all will be well.
The rectangular symbol is for TO220 not TO126 coz my stupid PCB software don't have it. The picture is just to show what the final think will look like. I will remove the rectangles in the final version(which I am going to build myself too).
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
