Simple Symetrical Amplifier
Old 12th October 2012, 04:56 AM   #3411
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
It seems, the text on Shaan's first PCB lay-out confuses others.
The corrected PCB with the readable text (left image) and Naf's posted corrected PCB with the reversed text (right image) are both correct for toner transfer. No need to mirror. See the components lay-out (center image), the imaginary copper tracks and both the b&w bottom copper tracks matches. Personally I don't mind the text but I look into a particular spot in the pcb artwork, and in Shaan's design the input. The input in the component lay-out goes to the right side and in both the b&w bottom copper (for toner transfer) the input was also on the right side, then that is good to go for toner transfer. Of course after the image has transferred to the pcb it will become reversed but then you will be flipping the board so that the parts sits on top of the board and not on the bottom copper exactly just like on the given component lay-out..
Old 12th October 2012, 05:04 AM   #3412
de Ocampo's Avatar
Perfect DIY...well almost...
Old 12th October 2012, 06:34 AM   #3413
naf is offline naf  Indonesia
Yihaaa.... nicely done ...perfect DIY
Old 12th October 2012, 06:41 AM   #3414
you've got it!, i'm always print it in paper and see throgh the light before toner transferring...and that's why i manually flip SHAAN and SSA text.
Old 12th October 2012, 09:02 AM   #3415
boyet0173 is offline boyet0173  Philippines
Hi abetir,
What paper did you use to transfer the toner in the pcb?
Boyet
Old 12th October 2012, 10:42 AM   #3416
shaan is offline shaan  India
shaan's Avatar
I think it's magazine cover...
V4 GB! | V4H GB!! | PSU GB!!!
Old 12th October 2012, 11:20 AM   #3417
de Ocampo's Avatar
..pretty close Shaan..
It's actually an A4 copy paper wrap.
boyet,
I was told the A4 size stickers being sold at National Bookstore is ideal for use on toner transfer method (you won't be needing the sticker of course just take the "backing paper"), better yet check on the "Staples" brand. I dunno' if you can find the "wrapper" that I've used, it was actually for office use, but I guess any glossy type paper that can tolerate heat without peeling off, should be good enough for the job.
In laserjet toner transfer method, "practice makes perfect"
Old 12th October 2012, 11:24 AM   #3418
de Ocampo's Avatar
Thanks Naf!
I just hope I can populate the board the soonest...right now i'm feeling real slow working on my other amp build.
Old 12th October 2012, 12:09 PM   #3419
shaan's Avatar
Very nice abetir. Waiting to see another happy SSA owner!
Old 12th October 2012, 12:38 PM   #3420
daudio25 is offline daudio25  Europe
Dear Lazy Cat ,
can you suggest what to change in schematics to adapt it to 40-45VDC regulated PSU or even 56VDC if not regulated (didnt decided yet)?
http://www.diyaudio.com/forums/attac...-basic-pcb.jpg
And output transistors.I have MJL21194/15025 but theese are too slow i guess,only 4mhz. I have NJL3281 too which is 30mhz device but it's with diodes ,different pinout.But that's managable if needed.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
