Simple Symetrical Amplifier
Old 10th October 2012, 01:32 PM   #3391
mathez is offline mathez  Indonesia
hi shaan, can i supply with +/-45v for SSA ,is there any change
thanks.
Old 10th October 2012, 01:45 PM   #3392
shaan is offline shaan  India
shaan's Avatar
thanks.
I haven't tried it with +-45V but a quick simulation shows the following changes.
1: 470ohm Zener feed resistor increased to 1K.
2: 1K2 Current feed resistor might need to be increased to 1K3. As the higher PS potential causes high current draw in VAS.
3: Removal of one of the 1N4148 diodes and use only one to bias the FETs to about 175mA.
The input bias and VAS bias must be carefully set with varying the 1K2 resistor. You will probably get reduced THD with higher PS voltage. And of course more power into same load.
V4 GB! | V4H GB!! | PSU GB!!!
Old 10th October 2012, 01:50 PM   #3393
okey shaan,coz i have etch the PCB,but my PSU +/- 45v..
thanks
Old 10th October 2012, 01:51 PM   #3394
Cambe is offline Cambe
Hi Shaan,
Thank you, I did the same thing with Version 1.4 PCB post #498. Version 1.4 is corrected now and I have all the parts for it so,I will start on it while awaiting parts and new PCB material for the PEECEEBEE.
Old 10th October 2012, 02:01 PM   #3395
shaan's Avatar
thanks
Nice.
Just a little tip for safety. The single 1N4148 diode's anode goes to the previous upper 1N4148's anode, and the cathode goes to the lower one's cathode. Nothing goes through the two holes inside the blue borders shown in the attachment.
Old 10th October 2012, 02:03 PM   #3396
shaan's Avatar
Hi Cambe I saw that post. ( )
All the best with the V1.4 PCB.
Old 10th October 2012, 02:13 PM   #3397
Originally Posted by shaan View Post
Nice.
ok shan , i will always need you,to finish this amp
Old 10th October 2012, 02:24 PM   #3398
naf is offline naf  Indonesia
number 20 of 20 Reasons To Go For SSA
Old 10th October 2012, 02:30 PM   #3399
Esperado is offline Esperado  France
Banned
Just a little tip for safety..
Don't you like straps ?
Old 10th October 2012, 02:40 PM   #3400
shaan's Avatar
No.
But yes despite looking ugly, they might be useful here.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
