Simple Symetrical Amplifier
Old 9th October 2012, 05:46 PM   #3361
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by shaan View Post
It's a Keltron 100uF/40V. Indian make, orange.
Try 1000uF and/or bypass, maybe there is some more sonic hiding there somewhere.
Old 9th October 2012, 06:00 PM   #3362
shaan is offline shaan  India
shaan's Avatar
May be, may be not. I already tried a lot of caps in signal paths of various amps and the ones I use in my current experiments are the filtered ones.
Old 9th October 2012, 06:15 PM   #3363
Salas's Avatar
Same type but bigger value in the specific place, you tried?
Old 9th October 2012, 06:17 PM   #3364
shaan's Avatar
Not in SSA, yet.
edit: I will update once I do.
Old 9th October 2012, 06:34 PM   #3365
Esperado is offline Esperado  France
Banned
Originally Posted by Salas View Post
....Shaan that is a fresh build
Not to forget that a lot of people don't like changes in their equipment, at first sight and until they are used to it. And that some amp can have defaults witch can compensate source problems ?
I used to test many amps in my studio. (Manufacturers wanted to have some "studio reference").
Unless the amp was pitiful (8/10) and eliminated after 3 minutes, it was only after one day working with it that i was able to make my opinion. I remember that some amps, looking impressive at first listening, can make mixing process very difficult.
That makes-me remember that my favorite was a Studer, CFB if i remember well. Something plugged-in and forgiven because its transparency.
Old 9th October 2012, 06:53 PM   #3366
Salas's Avatar
Can't say, more when I will visit. Meantime he will try BF245C local CCSs, 1.5K feedback resistor instead of 2k2 is next (ups OLG to 45dB and FB to 21dB).
Old 9th October 2012, 07:17 PM   #3367
Salas's Avatar
Yes. But I was particularly talking in respect to the resistor current only. There may be many more ways to change the current through the VAS, like increasing the PS voltage.
Its a bridge system, balancing factors are many to tweak, yes. There is no VAS by the way, its just a 2 stage amp, thus challenged for OLG. There is an input symmetrical cascode and a Sziklai BJT-LATFET compound output pair.
Old 9th October 2012, 07:29 PM   #3368
shaan's Avatar
Common emitter output? Hmm, then I think the resulting sound will be way different from my build.
Old 9th October 2012, 07:38 PM   #3369
Stee is offline Stee  Italy
Stee's Avatar
Default Maybe a BJT final device?
don't like mosfets
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 9th October 2012, 08:05 PM   #3370
Salas's Avatar
Sorry, its source follower like yours.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
