Simple Symetrical Amplifier
Old 6th October 2012, 06:21 PM   #3311
shaan is offline shaan  India
shaan's Avatar
Hi doors, would you like making your own? Then check the following link.
PEECEEBEE
V4 GB! | V4H GB!! | PSU GB!!!
Old 7th October 2012, 12:21 AM   #3312
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Shaan, you're a good karma!
people from the other side of the world are filling-in..
BTW: ..been looking for the schematic on this one, has anyone successfully built it? with the inclusion of the PSU on board, quite compact!
Old 7th October 2012, 02:39 PM   #3313
shaan's Avatar
Hi abetir. I just want to help spread the sonic pleasure of SSA. Thanks.
The awesome PCB by sir Alex is Nico's version. You can see the schematic here:- Nico's SSA Schema
And may want to see what nico has to say about the sound it delivers here:- SSA Experience
The circuit has been built and tested by Nico as he reports its his daily-use amp. However, I'm not sure if he built it on exactly this PCB or not. I couldn't see any errors in this PCB, so think you can give it a try. ALL will help.
Old 7th October 2012, 02:54 PM   #3314
naf is offline naf  Indonesia
Hi Abetir, you can search pcb by sir Nico, he've uploaded his pcb too.
and he recomended pcb by sir Alex_mm, try search for pcb rev. 1.4 of Nico's SSA version by sir Alex_mm.
Hi Shaan,
today i've completed my second channel, with more better parts.
it' is still okey for 33pf instead of 22pf?
thanks,
naf
Old 7th October 2012, 03:23 PM   #3315
shaan's Avatar
Hi Naf. Congrats! Yes it is okay. You can use even a 100pF with no problem.
Hi Abetir. You can get the layouts in PDF right here:- Alex's SSA-Nico V1.4
Old 7th October 2012, 03:43 PM   #3316
Originally Posted by shaan View Post
Hi Naf. Congrats! Yes it is okay. You can use a 100pF with no problem.
Thank you Shaan,
my first channel using 47pf and this second channel i try using 33pf
my measure so far is good:
vas bias at 14 ~ 15 mA
offset -0.2 ~ 5 mV
my second channel "the red one" is lit
Old 7th October 2012, 03:59 PM   #3317
shaan's Avatar
Your measure is same as mine.!.
The active devices are a mirror copy of the ones I used here! LOL
I rechecked the offset again and it reads 11.5mV.
P.S. peeceebee with servo is almost done.
I found a PCB maker here named Nutech and hopefully will get a bunch of them soon. HOHO
Ooh! RED LEDs look HOT! COOL! Nice job naf!
Old 7th October 2012, 04:08 PM   #3318
nice to hear a servo version nearly done...
Old 7th October 2012, 04:18 PM   #3319
Ho ho ho .. "the red one" is singing beautifully.
Old 7th October 2012, 04:24 PM   #3320
shaan's Avatar
NICE NICE NICE!~!
Last edited by shaan; 7th October 2012 at 04:28 PM. Reason: already know bias and offset.. okay i'm and idiot
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
