Simple Symetrical Amplifier - Page 329 - diyAudio
Old 1st October 2012, 09:19 PM   #3281
Banned
Originally Posted by Riff View Post
+50 to -50 is max rail?
For the power units, yes. Not enough power ?
Old 1st October 2012, 09:34 PM   #3282
Riff is offline Riff  Indonesia
Riff's Avatar
can this monoblock produce about 40vrms output at 1,6R and rail voltage is +65 to-65 (1kw)?
or i need to add some output?
sorry my bad eng...regards.
Old 1st October 2012, 10:03 PM   #3283
shaan is offline shaan  India
shaan's Avatar
Hi Riff, Welcome to the thread.
Do you intend to use SSA as Subwoofer amp? Or multiple speakers in parallel? I believe the version you chose has the ability to drive 1.6ohm if you increase power transistors at the output. It has enough driver power for a lot of power trannies, but how many I cann't tell. Hope LC and others shed some light on this. I'm excited.
PeeCeeBee V1.1 Here, V2 Here and V3 Here
Old 1st October 2012, 10:16 PM   #3284
Riff's Avatar
ur wellcome shaan...hope i can learn something from this thread...my plane is multiple speakers in parallel for outdoor.
anybody can tell me how rail to get 40vrms output at 1,6R?
7pair of 2SC5200/2SA1943 is enough?
Old 1st October 2012, 10:32 PM   #3285
shaan's Avatar
With 7 pairs there will be over 3.5A of peak current through each device with 40VRMS(57VPeak) into 1.6ohm.
With 60VCE the SOA curve of 5200 tells max continuous Ic of just below 2A. So you'll need 13 pairs for driving that load from +-60V.
I hope I calculated it right.
edit: This would put 1Kw into 1.6ohms, so 13 pairs seems okay.
Old 1st October 2012, 10:40 PM   #3286
Banned
I do not understand. this amp is able to deliver around 68V rms. What is your requirement, which usage ?
I believe 1.6R is not a big deal* if it was well calculated and will probably do not require much more power units as long you do not run-it on continuous power. Your main problem will be the power supply and cooling.
* Not sure, i don't designed-it and don't know the safety area of the power Transistors
[edit]Nice Shaan, our messages crossed.
Old 1st October 2012, 11:03 PM   #3287
shaan's Avatar
Yes you are right Christophe, none here has built it with so many output devices. I will wait for LC's input on this matter, as this approach hasn't been tried with SSA before. A successful 1KW SSA build will be a great project for the expansion of this topology into very high power range.
Old 1st October 2012, 11:16 PM   #3288
Banned
Care has to be taken regard to the driver's charge, not too much disparities between power units, or increase of their emitters resistances, forced air cooling etc...
As it, it looks ok to drive some special home speakers (condensers or magneplan) at good listening level.
> 1KW, for PA, by example, is just affraying. I would prefer Class D, for that kind of usage.
Old 1st October 2012, 11:23 PM   #3289
shaan's Avatar
That's right Christophe. Class-D is actually better in this respect, but I doubt any Class-D can do what SSA can, sonically speaking.
If I am on the right track, we definitely need a Class-H SSA.
Old 2nd October 2012, 12:43 AM   #3290
Banned
it is out of topic, but PA does not require such subtlety. It require clear, dynamic, and free reproduction, that all about Class D amp. Again, i wonder why Class D has such a bad reputation.
One of my friends, a very clever and passionated hifi and music lover, audiophile, in the good sense of the word, and DIYer had chosen Class D amps between everything else for his high end system to power those enclosures:
Enceintes acoustiques de référence (Look at the bottom of the page at the response curve and the group delay...)
The amps are here:
Mon système (use google translator ?) -> Amplificateur 2x300W classe D and http://www.dcx2496.fr/img/UHT849.jpg
He said it is the most transparent natural and dynamic amp he had never listened to.
Well, i hope he can compare, one day, with a SSA.
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
Copyright ©1999-2017 diyAudio
