#3201 |
Anybody know how to test the usefulness of the R-D strings in the supply rail with simulation?
#3202 |
Depends on the reason you have for using R-D strings. You need to test it's usefulness for that goal.
That goal could be supply filtering, supply impedance, supply sag reduction... So your question is very vague. |
#3203 | |
I wanted to know one good reason.
That's the question. Except that my goal is the best overall performance. Quote:
I was afraid that rough simulation will not be precise enough to predict it's behavior... |
#3204 |
Simulation could tell you performance specs, but those specs on't tell you if you ill like the result or not if your goal is to enjoy the sound. Simulation ill help you understand hy something changes the sound, provided you already have empirical observations to begin ith. So the process in this sense is backards: test first simulate after to understand.
As for filtering, I think it is orth a try on the current sources and/or the VAS, since there are still unprotected Early junction effects, but I think the difference ill be small. I think there may be a bigger improvement if you filter the rails ith my poer K-multipliers, so the FETs get a regulated rail. Hoever my Kmultipliers seem to ork much better on BJT output amps. I don't have a lot of experience here but the small signal area of the amp seems ell protected from the rails. Another factor is rectifier spikes on the rails, if your supply isn't ell filtered. |
#3205 |
Yes, I can build this SSA without servo .My heatsink only warm... i can touch with my hand as long as i want. |
#3206 |
Without support and help from you, shaan and esperado a newbie like me maybe wouldn't hear the beatiful sound of SSA.
.I'm using Bookshelf Speaker build by an expereinced DIY'er from my country. |
#3207 | ||
Power supply should be part of amplifier design. I started with transformers I have on hand. Lowering and (often) raising rail voltage of a finished amp will reduce performance
#3208 |
Sorry to ask a stupid question , due to my poor English: What is R-D strings ?
#3209 |
Today, i connect my SSA to my speaker,
and for the first time i hear a beatiful sound of this Amp. Natural Vocal, nice bass and crisp treble and more important it stable. |
#3210 |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
