Simple Symetrical Amplifier
Old 28th September 2012, 08:11 AM   #3171
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
I noticed in spice that when I added a cap in the FB path it raised the H10 - 20 noise floor.
I also noticed also in spice when I added a servo it raised the H10 - H20 noise floor.
In both cases lowering the lower -3db frequency reduces this problem into insigfificance but the servo needed a lower -3db frequency than the the FB cap to achieve same noise floor.
The servo spoiled the sound of the amp until the -3db frequency was lowered.
This might suggest that a FB cap is a better solution than a servo but with a servo once the frequency has been lowered it is effectively out of the audio band and sonically invisible whereas the FB cap - whatever the value - is always present throughout the audioband and will influence the character of the sound to some extent.
My take home message:
Avoid both Caps & Servos if possible and, as Christophe says, with SSA it is possible
Old 28th September 2012, 08:16 AM   #3172
sonnya is offline sonnya  Denmark
sonnya's Avatar
A circuit can be build not to use servo or caps, but servo is needed if your previous source sends out DC.
For commercial i would not run without a cap or servo.
If you have a gain of 21x and your previous source outputs +/-50mV => +/-1050mV at the speakers.....
Old 28th September 2012, 08:35 AM   #3173
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by RNMarsh View Post
can you design circuits which do not require a dc servo? -RNM
As my dear and respected friends already explained, SSA doesn't require DC servo for proper operation. It is integrated in the nature of an input stage that only small thermally caused Vbe voltage differences offset the SSA from zero, usually within +/- 50 mV range but not more than +/- 100 mV.
This offset can be set and compensated to close to zero mV by some steps-measures:
- input pair thermally coupled
- NTC to monitor input bias curent via mid FB DC voltage level
- high precision CCS to set input bias
SSA BIGBT HP I made in June 2012 is working without any DC servo, it is completely DC coupled and it works in recording studio on daily basis since then.
Old 28th September 2012, 09:24 AM   #3174
shaan is offline shaan  India
shaan's Avatar
Yes. Would you like some LTP, with maybe little flavor of mirrors?
Originally Posted by mikelm View Post
With a servo once the frequency has been lowered it is effectively out of the audio band and sonically invisible whereas the FB cap - whatever the value - is always present throughout the audioband and will influence the character of the sound to some extent.
Agree.
Totally agree. However, a servo is being added for the freshly-into-SSA diy-ers for whom I like the great SSA to be one of their first circuits which works with minimal "setting" and is reliable and safe and won't make a hole in their pockets. Every time I log in I see a lot of new people online in this thread, often more than 15. Won't it be great if some of them become interested in SSA and could enjoy it in a friendly and easy way? I can bet no one can leave the SSA once he/she hears its magic, and will inevitably be pushed to learn more about it, and maybe develop their own "suitable" or "complex" versions of SSA.
Very true. I have lost a fine speaker this way, and I had only one of them and now they are out of production.
Of course.
IMHO, second and third options are a lot more complicated in implementation than the first one which requires only a drop of heatsink paste and a zip tie and also limit the total number of parts to a minimum, preferable to guys who like the KIS approach. However, the three steps, when taken together, will definitely make the servo unnecessary.
Choice... the problem is choice. Thomas A. Anderson
Old 28th September 2012, 12:03 PM   #3175
Jay is offline Jay  Indonesia
Banned
Originally Posted by homemodder View Post
Oh you thought the circuit was new too.....
Yeah, audio amplifier electronics is not rocket science. There's nothing new under the sun, but...
I have had simple solution for this certain SSA issue. I couldn't believe that it was an invention, because I have never seen such solution before. But later on I saw a CFB amp implementing the same thing.
So, I think it is not about which circuits, old or new, but why you choose it.
CFB amps has been around since year 1. But even today everyone is arguing about CFB versus VFB.
Old 28th September 2012, 12:28 PM   #3176
homemodder is offline homemodder  Portugal
Do you mean solution for the temp compensation of the input pair or the Dc offset, why not post it if it doesnt change the rest of the design.
Old 28th September 2012, 12:32 PM   #3177
shaan's Avatar
I never claimed I "designed" a certain circuit, or SSA, or any other amp for that matter. So I don't care who's the person that posts such sarcastic comment like Mr. RNMarsh did. If it was the prime minister of India then he would be treated the same way. People should look at homemodder and learn how not to behave in diyAudio.
Old 28th September 2012, 12:34 PM   #3178
Mooly's Avatar
shaan and homemodder.
Any more personal insults or goading will result in bintime. Keep to the topic and keep it constructive.
Old 28th September 2012, 12:36 PM   #3179
Youre showing it perfectly, never heard of treat others as youd want them to treat you.
Old 28th September 2012, 12:41 PM   #3180
ashok is offline ashok
ashok's Avatar
......So I don't care who's the person that posts such sarcastic comment like Mr. RNMarsh did.......
One day you might feel sorry for having said such things.
You know what a " GURU " is don't you ? In our country we are taught to give the utmost respect to our Guru's.
RN Marsh is one of our Guru's !
Did you ever Google to check who he is ?
Here is one.
Marsh Sound Design ~ Experience the Sound with Marsh Sound Design Products !!!
Grow up young man .It's never wrong to make a mistake provided you learn from it ........and make up for it !
Cheers.
AM
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
