Simple Symetrical Amplifier
Old 26th September 2012, 08:24 AM   #3151
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by shaan View Post
Anyways, I am currently simulating my SSA with a servo, in order to eliminate my headaches/confusions/doubts/caring about offset once and for all, concentrating solely on the bias of the input and VAS.
Maybe something in this way ...
Old 26th September 2012, 09:35 AM   #3152
ersa191 is offline ersa191  Equatorial Guinea
I have a little problem finding common part BF245B local stores have only A,C grade. is this OK or should I go for other jfet like 2N5459? The amp is TSSA BIGBT HP?
Old 26th September 2012, 10:00 AM   #3153
Lazy Cat's Avatar
2N5459 is OK if its Id is more than 8 mA at Vgs=0 V, so it has current regulation margin more than 100% at 3 mA idle Id. Of course Rg has to be trimmed to get correct current value and than replaced with fixed resistor.
Old 26th September 2012, 11:07 AM   #3154
shaan is offline shaan  India
shaan's Avatar
I am simulating something in this way.
Red trace is amp freq response with 10uF input cap. Green trace is servo response. As simmed, the servo with the shown values would work at about 0.2Hz and quickly fall in response in both sides. I used this with my DOZ amps and it worked pretty well, the thing to keep in mind is not to provide voltage gain in the VLF zone where the servo will work.
Old 26th September 2012, 11:36 AM   #3155
sajti is online now sajti  Hungary
You can avoid the 100ohm resistor, or change it to some 1-10k. 100ohms means hard load for the opamp, and no necessary.
Sajti
Old 26th September 2012, 11:38 AM   #3156
Is the 1M is not too high? How much input offset it can handle?
Sajti
Old 26th September 2012, 12:22 PM   #3157
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
When I tried a servo on my fetzilla the nice qualities were lost ( transparency, spaciousness & bass integrity ) unless I set the -3db point to an incredibly low subsonic frequency so I will be interested to hear your before & after impressions.
Good Luck !
Old 26th September 2012, 12:29 PM   #3158
Lazy Cat's Avatar
Sajti
Nope, there will be max +/-1 V on 100 ohm meaning max. 10 mA OP amp output current.
Old 26th September 2012, 12:38 PM   #3159
FdW is offline FdW  Netherlands
FdW's Avatar
There is a DC-servo'ed version that I posted (some time ago) maybe it is helpfull Simple Symetrical Amplifier post #1063 (it includes a simulation file).
Old 26th September 2012, 12:52 PM   #3160
shaan's Avatar
Sajti
Yes. Thanks for the tip. With 100K resistor from servo to input it can handle +-5V of output offset(will it ever happen? dunno).
If the servo is just removed then the default offset with the 10K from input to ground is about +900mV, with the currents in the upper and lower halves balanced.
Good Luck !
Yes this happened in my listening tests with DOZ too and I had to increase the capacitor at the servo from 1uF to 4.7uF and decrease the feed resistor from 100K to 33K, with a -3dB of about 0.4Hz. Obviously the servo was adding its own voltage gain to the amplifiers LF response. There was funny cone excursion with the default values.
I will add the servo to my SSA and update ASAP.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 03:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 11:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 09:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 02:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 11:27 PM
