Simple Symetrical Amplifier
Old 21st September 2012, 02:49 PM   #3111
Cambe is offline Cambe
That was fast shaan
The size of the board is still to big when viewed. Even when I select View - actual size.
Old 21st September 2012, 03:47 PM   #3112
shaan is offline shaan  India
shaan's Avatar
Originally Posted by Cambe View Post
That was fast shaan
This is because my PCB software does not output pdf and I had to use online image-to-pdf converter.
I think you can scale the material to custom size in the print options. Also, inserting the png in an A4 page in word processor like MS Word will allow scaling the image to exactly 3.5x3 inch while keeping the sharpness intact.
V4 GB! | V4H GB!! | PSU GB!!!
Old 21st September 2012, 03:57 PM   #3113
naf is offline naf  Indonesia
Hi Cambe, try this, i use this to toner transfer my board
Old 21st September 2012, 04:24 PM   #3114
shaan's Avatar
Hi Cambe.
I checked the PDF posted by naf. This will work. Recommended.
Hi naf, what software do you use to make these PDFs?
thanks.
Old 21st September 2012, 04:50 PM   #3115
Originally Posted by shaan View Post
Hi Cambe.
thanks.
i use faststone image viewer, setting it to correct size 3.5 x 3 inch and print it to pdf using pdf factory.
And here may final board.. just to make building this beautiful Amp more easier for rookie builder like me
tomorrow i'll source all part and start to build.
wish me luck.
thanks
Old 21st September 2012, 05:13 PM   #3116
Thanks shaan and naf.
naf very nice looking PCB's
Old 21st September 2012, 06:34 PM   #3117
shaan's Avatar
Oh sh**!
GREAT PEECEEBEEZZ naf!
Best of Luck!
Old 21st September 2012, 07:12 PM   #3118
shaan's Avatar
Hi naf. Many thanks for info on faststone and pdffactory; small apps and very easy to use. Life is going to be easier from now on.
Old 22nd September 2012, 09:54 AM   #3119
OMG, i miss 1k2 in my material list .. .
ok i'll series 1k + 220r resistor. Dear Shaan/LazyCat is this ok with this series resistor?
btw here my progress.
thanks
Old 22nd September 2012, 11:08 AM   #3120
shaan's Avatar
thanks
Yes 1K+220 is perfectly OKAY(I am doing this too). In fact, you may need to modify these values after checking the initial bias, which may not be optimum at first.
Board looking good with parts.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
