Simple Symetrical Amplifier
Old 31st August 2012, 01:26 PM   #2881
Esperado is offline Esperado  France
Banned
Originally Posted by ashok View Post
Is it on one of the pages of this thread ?
Yes, and you will find many detailed photos of this exceptional realization too.
Look this post and before:
Old 3rd September 2012, 01:20 AM   #2882
shaan is offline shaan  India
shaan's Avatar
Today I put my ear over the speaker and...
There is HUM!
Faint, but present... normally not detectable... but head too close and "mmmmmrmrmrmmmrmmrmrmrrmrm".
I increased the fb current-feed resistors from 1k2 to 1k5, and the hum almost vanished. But, Iq is now 70mA; and only 3mA through the VAS.
I suspected the PSRR. Off to my PC and simulated the following, a 15V capacitance multiplier. Seems okay in the sim. I was wondering whether others have experience with it, there. As it is known that the +-15V must be as clean as possible. Please. Or should I just double parallel-to-zener capacitance?
Thanks in advance.
P.S.- NO complaints about the music. It's as good as it was. With 1k2 current-feed resistor of course.
V4 GB! | V4H GB!! | PSU GB!!!
Old 3rd September 2012, 01:38 AM   #2883
Banned
Originally Posted by shaan View Post
There is HUM!
Are your grounding well designed (star) ? Did this hum stay the same when no source connected ?A capacitance multiplier is a good (very good) soundig choice for main power. For +-15 v, i would prefer a low noise regulated circuit.
Old 3rd September 2012, 02:11 AM   #2884
shaan's Avatar
My grounding is star. The hum is there with no source connected or input short to ground or zobel at the output. Otherwise the amp is very stable and sounds superb.
I think I will start with doubling the capacitors first.
Old 3rd September 2012, 03:07 AM   #2885
Banned
Return line from speakers direct to the common point of the PSU? Input grounds isolated from chassis and amps et direct to this point too ? Experiments for the best grounding point on the chassis ? No oscillation ?
Old 3rd September 2012, 04:25 AM   #2886
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I use a cap multiplier on my TSSA. Without it there was a small hum but with the multiplier it is dead quiet.
Old 3rd September 2012, 05:37 AM   #2887
Svjatoslav is offline Svjatoslav  Ukraine
[LEFT]There is HUM!
The power supply is common to the two channels? If so, in each case it is necessary to look for other connection point ground.
This can be time consuming.
To avoid this, apply a separate power supply. For each amplifier left and right channels of their own, independent.
Increasing the capacity of the filter capacitors will not help.
Old 3rd September 2012, 05:56 AM   #2888
My build is double mono.
Old 3rd September 2012, 07:02 AM   #2889
shaan's Avatar
Yes.
I built only a single board. I am talking about the capacitors parallel to the zeners. Thanks.
I plan to do the same.
Old 3rd September 2012, 07:03 AM   #2890
shaan's Avatar
I was wondering if a cap-mult could help with the feedback current supply, in Class-AB SSA.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
