#2851 |
Bonjour Christophe
http://www.audiodesignguide.com/Head...inputstage.JPG This schematic look like current FeedBack but with Jfet |
#2852 | |
#2853 |
Indeed, THD figures for that amp are very good, Ive got 7 of these amps, 5 see daily use in bars (14 hours a day), 2 spare. They are however very reliable so spare ones are still boxed and never used. Its practically a SSA with hawksford cascode. Output uses Class H circuitry, bipolar and Mosfet.
#2854 |
In fact I would like BJT input as SSA
#2855 |
Theres not much of a choice nowadays anyway, there are no more toshiba complementary JFETs around, the ones that can be used in such a input stage have to be purchased in 1000 s to maybe get 100 pairs matched to Idss and gm.
#2856 | |
No need for adaptation if this is the pioneer you were talking of. (The shematic i founded with google was absolutely different). [edit]Why did-you like to change input's JFETs by a BJT ? They have their own advantage (noise factor/bandwidth/impedance).. Last edited by Esperado; 29th August 2012 at 07:24 PM. |
#2857 |
This schematic ( with 2sk1058 ) could have the same speed as your AMP ?
I have matched 2sk246Y 2SJ103Y |
#2858 | ||
Same here. And I think the SSA is better than the headphone amp (just use the same BD139/140). The head-amp "trick" to lower distortion has consequence with the sound (tho not easily recognized). It is better using a string of dual silicon diodes like in the SSA. The resulting THD (and offset) will not as low as the head-amp but who needs super long trailing zeros anyway. |
#2859 |
Hello Jay,
I pasted this site link to illustrate my request about the SLC I would like to make a very fast and linear amplifier with lateral mosfet output 2SK1058. The speaker : http://www.hometheaterhifi.com/image...ance-phase.gif Last edited by DIGORA; 29th August 2012 at 08:48 PM. |
#2860 |
Hi digora.
Go for SSA, which is damn fast, super linear and has large power output.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
