Simple Symetrical Amplifier
Old 29th August 2012, 08:43 AM   #2841
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by mikelm View Post
Do you notice degradation even if you have a small cap in parallel...
...any thoughts on that ?
mike
I have seen a 0.1uF MKT capacitor across all cathode auto-bias fuses in all Jadis tube equipment.
Old 29th August 2012, 10:51 AM   #2842
Esperado is offline Esperado  France
Banned
I wonder what can be the purpose of this cap ? To prevent the fuse from blowing with very high HF ? To prevent the spark when the fuse blows ?
Old 29th August 2012, 11:21 AM   #2843
Salas's Avatar
Spark I guess is the primary goal, as I have seen highly biased tubes failing violently near their life's end. I wouldn't be surprised if that most respected artisan French tube amps company has some subjective sonic beliefs about using them also.
Old 29th August 2012, 11:26 AM   #2844
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
The purpose of the cap is to partially absorb any noise caused by poor connection between fuse & fuse holder
Old 29th August 2012, 11:32 AM   #2845
Salas's Avatar
That, or some little HF part of non linear cathode feedback signal added by the fuse as it merrily passes bias swing in series with the cathode resistor? They use resistive auto-bias in almost all their models.
Old 29th August 2012, 12:23 PM   #2846
dipolar is offline dipolar  India
dipolar's Avatar
This thread has taken me into different dimension of world.
@Shaan ,Awesome PCB soldering/wiring there, beautiful !
Old 29th August 2012, 12:32 PM   #2847
homemodder is offline homemodder  Portugal
we await with interest
Below find input section of 1) 1995 German Class H high power PA amp Input circuit. (See the similarity of the amp presented in this thread.
2) Sony N1 CFB from 90s. (I like this circuit, see the twist in the vas.
Pioneer models still to come, I am having problems getting schematics in electronic form.
Old 29th August 2012, 03:24 PM   #2848
DIGORA is offline DIGORA  Belgium
Do you know the Pioneer Super Linear Circuit ?
This circuit could be adapted to use a current feedback as SSA?
the Headphone amplifier
Old 29th August 2012, 03:28 PM   #2849
dadod is offline dadod  Croatia
dadod's Avatar
2) That is Hawksford enhaced cascode.
Old 29th August 2012, 03:40 PM   #2850
Banned
If i make no mistake, the Pioneer Super Linear circuit used no global negative feedback, apart DC servo. So, the response would be: no.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2017 diyAudio
