#2821 |
Thank goodness they are not available here, audiophools are still a rarity in India lol. My about to arrive 10uF film caps cost INR100($2) each and I don't believe in snake oil stuff.
SSA Important Post Links:- How SSA Works, Nico's SSA, Nico's Thoughts on SSA Sound, Alex's SSA Mono PCB, LC's Scope Traces, SSA BIGBT PCB, SSA High Power Low Zout PCB, PeeCeeBee, SSA Speed, Why Current Feedback, Why SSA Is Unique, 20 Reasons To Go For SSA |
#2822 | |
#2823 |
I think a.wayne was correct in his observation. There are many things affecting the performance. One of them is the trace inductance as Esperado has mentioned. So there must be a balance considering all possible parameters affecting the performance.
If there is a parameter to suspect, I think it is the maximum ESR. For cheap caps, big capacitance is a big no-no. But for good caps, big capacitance is fine. Also, they mentioned about higher voltage rating having lower distortion. I have no observation with power supply caps, but I have observed and practiced this with output caps. About one big versus many smalls, it is almost similar to tone control phenomena. When you get good treble, you get bad bass. When you get good bass, you get bad treble. |
#2824 |
#2825 |
I prefer coffee. But, I still think you are quoting for an apples and oranges comparison
#2826 |
I have done the multiple little cappy thing , I did not like the bass , worst the amplifier had no energy, best was as discussed previously , big ballsy bwoys in the main psu , smaller caps closer to outputs on board ...
Copper bars instead of wire , everything as short as possible .... Just saying ... |
#2827 |
#2828 | ||||
This protection isolate the loudspeaker during power on/off for no click, noise etc.. and provide a soft current charge in the PSU caps. I would not like to short circuit the Amp output during this time where offset can Rock'nroll in a funky way ;-) I'm unable to hear any difference between the relays and a big wire soldered across their contact. So, I'm not emotional about it. Yes, my loudspeakers are impedance compensated both motional and zobel (i highly recommend) , so they present a quasi flat impedance curve, and, so, slight difference in damping factor (internal impedance of the amp) by the (very) little resistance of the relay's contacts is not so sensible. Last, you can parallel an active device to reduce further this resistance and contacts problems. I use Big relays with two paralleled contacts for each channel. Of course, you can forget about protection, (a strait line wire is less expensive and sound the best ) if Murphy ignore where you are living. I write this under his supervision. Last edited by Esperado; 28th August 2012 at 04:48 PM. |
#2829 |
Best no protection , no fuse straight to speaker , of course very dependent on system resolution.
#2830 |
IF one has to use an input coupling cap, I am affraid some people would be able to hear differences between different cap types. For those unlucky to be in such situation
I can tell that I just forgot about trying different types after finding those NOS Russian military surplus PETP caps cheap at eBay.
"Thou shall build big horn speakers" |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
