Simple Symetrical Amplifier
Old 29th June 2012, 08:29 PM   #2621
MiiB is offline MiiB  Denmark
Not to spoil the shutting down of the feedback discussion completely, but to state how I see things...I may be completely of track...but this makes sense to a mechanical guy...
Feed back compares levels...A real time scale lock...Trouble is that it comparing slightly time shifted levels...and with increasing frequency this time shift matters more and more and hence the distortion increases with frequency...makes perfect sense to me...feedback is not comparing wave-forms, it's comparing levels.
Old 29th June 2012, 08:43 PM   #2622
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Fully agree when you replace time shifted by phase shifted
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 29th June 2012, 08:46 PM   #2623
time is phase...or..??
Old 29th June 2012, 08:50 PM   #2624
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by Edmond Stuart View Post
Hi Sonnya,
At the moment I can't show you recent work yet*, but if you like, have a look at some outdated stuff from the past: here and here.
* At the moment I'm busy with translating a MicroCap file to FreePCB (PADS format) and after that, drawing the PCB itself. A hell of job and expensive too (to get an impression see the thumbnail of the schematic below).
As you see, it's the opposite of a Simple Symmetrical Amplifier.
edit: It's like a V8 engine with two desmodromic valves per cylinder.
E.
Or a pushpull driver for every mosfet. Your front end is vfb where i am more to cfb but complexity is the same in My cfb design with an modificede current mirror.
Go for orcad. In Denmark they have a lease plan. Then you Can combine pspice with sch and pcb. Or the more expensive dxdesigner with hyperlynx and pads interactive router
Old 29th June 2012, 08:59 PM   #2625
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Actually phase is a bit faster then local time but does not cary information.
Old 29th June 2012, 09:01 PM   #2626
Can be ....
Old 29th June 2012, 09:57 PM   #2627
Edmond Stuart is offline Edmond Stuart  Netherlands
Edmond Stuart's Avatar
Default "pour les couilles du pape"
Aaaaaaargh! Am I talking here "pour les couilles du pape"*?
If you are talking about a time shifted signal (inside a feedback loop), thus without amplitude roll-off at higher frequency, such system is unstable (by definition). If, under marginal conditions, it might happen to be stable, then it does not increase the distortion.
True.
Anyhow, you folks make me really angry, as you refuse to understand or accept that time shift is NOT the same as phase shift.
* In Dutch: "Voor de kat zijn kut".
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het lichtů(H.M. van Randwijk)
Old 29th June 2012, 10:21 PM   #2628
BenY is offline BenY
You are right,
Time shift description makes the feedback limitation much more easily understandible...
Phase shift issues in feedback are much more complicated to explain as they are also time shift but are also frequency depandent and involve additional compexity..
Old 29th June 2012, 10:26 PM   #2629
Right. BTW, the bunch of extra trannies cost me virtual nothing.
If you need the ultimate speed, admitted, go for cfb. But in my case I finally opted for the lowest possible distortion (THD-20k of the front-end is ca. 50 ppb) and lower offset.
Orcad? No way (I have used it once). I stick with MC, the most user friendly, versatile and fastest simulator you can get (it's written by real programmers, thus it's not bloat ware). The only drawback is that it is not integrated with a PCB package, though it does a translation to different PCB packages. But in most cases you have to (re-) define (or assign) the shapes and pins of the components (in conformance to names of the target S/W).
Old 29th June 2012, 10:30 PM   #2630
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Phase shift, we could even say frequency dependent time shift because of circuit's LC (not Lazy Cat) characteristics, to put Edmond's and Mikelm's explanations on common denominator, just in a sense to make an explanation easier.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
Copyright ©1999-2017 diyAudio
