Simple Symetrical Amplifier
Old 1st May 2012, 08:49 AM   #2491
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by Sheldon View Post
Superb design and craftsmanship! Wow!
BTW my latest iteration above, mounted on a proper heat sink is thermally well behaved. Driver bias goes quickly to 9.5mA, then over several seconds to about 11mA. Over the next few minutes it hits a maximum of about 12mA, then settles over the next few minutes back to about 11mA where it stays. DC offset changes a maximum of +/- 15mA, and settles within +/- 10mA. All quite acceptable.
Next is channel two, then plug it into the main system for a listen. Will probably take me a few weeks, between other things.
Sheldon
Thanks Sheldon
You see, SSA beast can be thermally tamed, now it's like a pat.
DC offset is OK, no need for servo at all.
Just take it slowly, in that way you have firm control, plus no stress.
Old 1st May 2012, 08:50 AM   #2492
Lazy Cat's Avatar
Originally Posted by keantoken View Post
Hey man, I think that painting is a bit crooked.
You should see the others.
Old 1st May 2012, 08:57 AM   #2493
Lazy Cat's Avatar
Originally Posted by igor0203 View Post
Congrats LC! This amp looks better than many commercial.
Thank you Igor.
Four hours of listening the upper setup showed the SSA amp can drive low efficiency/low impedance speakers effortlessly. Very transparent, high resolution, full harmonic presentation from 12" black discs.
Old 1st May 2012, 10:26 AM   #2494
Smiley 09 is offline Smiley 09  Europe
Smiley 09's Avatar
Smile In the SSA - TSSA - Music Veritas
Originally Posted by Lazy Cat View Post
I started this thread 9 months ago (how symbolic), continuing from here and today I finally made an amplifier that is finished, tested and auditioned to my friends.
It was a big pleasure making SSA BIGBT HP, learning process all the way, meeting new friends on the forum and continuing to develop new amps in TSSA thread.
Some pics from today's assembly and later music session in a system consisting of Clearaudio Ovation, MC Cartridge Stradivari V2, Nano Phono Preamp, Absoluta Talia stereo preamplifier, Magico V3 speakers, Ktema speakers.
Regards, Andrej
Andrej
My SINCERE CONGRATULATION to Yours Great Success in making Yours SSA AMP
such an Outstanding Performer while singing with (my faw. LP) - Vinyls.
Congrats to Yours fine assort. of the equipments selection You have.
I just imagine how You and the Yours friends were nice Touched with Pure & Pleasant
of Rich SOUND to all Souls being there....
I wish You all the nicest music enjoyment in the future . . .
Old 1st May 2012, 10:33 AM   #2495
igor0203 is offline igor0203  Slovenia
Thank you Igor.
I'm sure you were in heaven for those four hours...
Old 1st May 2012, 12:07 PM   #2496
guitar89 is offline guitar89  Malaysia
Maybe more than 4 hours perhaps ? After effect
Old 1st May 2012, 01:06 PM   #2497
Lazy Cat's Avatar
Originally Posted by Smiley 09 View Post
Andrej
Thanks for good wishes Smiley
Yes, all the way analog chain was the best performer in given system. Vinyl with analog recording material still holds the magic in music reproduction.
Old 1st May 2012, 01:14 PM   #2498
Lazy Cat's Avatar
We were enjoying all the session and it was, as usual, unawarely over too quick.
Old 1st May 2012, 02:26 PM   #2499
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Somehow analogue most often sounds like music and can give a lot more emotional fulfilment than can processed digital signal . The technical argument that digital source is more accurate does not hold water for me as it all too often cannot reproduce that magic which analogue so often does produce! This differential, for me at least, makes me very suspicious that the present state of art measuring instruments are usually measuring the wrong parameters.
Well done!!
Old 1st May 2012, 04:32 PM   #2500
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I heard very good digital master tapes but somehow it does does make it on a medium we can access. Refference Recordings sells copies of their mastertapes but then we are stuck with classical and maybe not the best preformance.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
