Simple Symetrical Amplifier
Old 27th April 2012, 05:47 AM   #2481
guitar89 is offline guitar89  Malaysia
LC, by the way, I haven't really established the ground setting. I'm thinking using the remaining big portion into ground plane by using jumper connection of wires. Which point should I take off from ? bottom center is a good choice ? (where junction of trafo & reservoir)
How will the 1uF paralleled would help ? (curiosity ~ !)
As for to filter ripples from supply rail, should I use a 1uF or 0.1uF cap ?
And how to determine the amount of bias for driver ?
Regards, Leong.
Old 27th April 2012, 08:57 AM   #2482
padamiecki is offline padamiecki  Poland
Thumbs up me too
Originally Posted by mikelm View Post
...I think my next build with be with separate voltage gain stage & Zero FB follower o/p stage - balanced throughout - I feel like trying a radically different topology
I am in
my about SSA: great design but the secret of good sound is current NF
regards, Pawel
Old 27th April 2012, 09:09 AM   #2483
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by padamiecki View Post
I am in
Thanks, agree totally.
Old 27th April 2012, 09:15 AM   #2484
Lazy Cat's Avatar
Hi guitar 89
I suggest you to use double "battery" pack power supply (separate +Vcc-00, -Vcc-0), GND meeting point on a PCB.
Driver's bias current usually set to class A regarding their output "drive" current to the next stage.
Old 27th April 2012, 01:00 PM   #2485
Originally Posted by Lazy Cat View Post
Hi guitar 89
I'm using single transformer for 2 channel, so I suppose I have to branch out each lead into 2 for each channel ? If I were to meet both secondary's 0V to form ground, then how will be the further connection form the ground ?
About the bias, I assume class A range is the Driver's half maximum output ? Is it roughly 75mA for 100W, 25mA for 50W ? (just guessing the amount... how to calculate/estimate the driver's drive current)
Old 27th April 2012, 05:16 PM   #2486
Sheldon is offline Sheldon  United States
Housekeeping added. Next step is mount to regular heatsink, test, then second channel:
Sheldon
Old 1st May 2012, 12:30 AM   #2487
Lazy Cat's Avatar
Exclamation SSA BIGBT HP finished amplifier
I started this thread 9 months ago (how symbolic), continuing from here and today I finally made an amplifier that is finished, tested and auditioned to my friends.
It was a big pleasure making SSA BIGBT HP, learning process all the way, meeting new friends on the forum and continuing to develop new amps in TSSA thread.
Some pics from today's assembly and later music session in a system consisting of Clearaudio Ovation, MC Cartridge Stradivari V2, Nano Phono Preamp, Absoluta Talia stereo preamplifier, Magico V3 speakers, Ktema speakers.
Regards, Andrej
Old 1st May 2012, 12:54 AM   #2488
Superb design and craftsmanship! Wow!
BTW my latest iteration above, mounted on a proper heat sink is thermally well behaved. Driver bias goes quickly to 9.5mA, then over several seconds to about 11mA. Over the next few minutes it hits a maximum of about 12mA, then settles over the next few minutes back to about 11mA where it stays. DC offset changes a maximum of +/- 15mA, and settles within +/- 10mA. All quite acceptable.
Next is channel two, then plug it into the main system for a listen. Will probably take me a few weeks, between other things.
Sheldon
Old 1st May 2012, 12:56 AM   #2489
keantoken is offline keantoken  United States
keantoken's Avatar
Hey man, I think that painting is a bit crooked.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 1st May 2012, 05:21 AM   #2490
igor0203 is offline igor0203  Slovenia
Congrats LC! This amp looks better than many commercial.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
