#2421 | |
Wish you the best outcome from your design, regards.
#2422 | |
#2423 |
I didn't like the sound of 100R in series with miller cap in my fetzilla but one cap with 100R and another in parallel without sounded fine.
I don't think KT is suggesting a tendency for oscillation rather just a tendency for low level ringing that spoils the sound. |
#2424 | |
#2425 |
This must be built and tested for, no point in speculating, it is not worth the time scrutinizing simulation when it is faster to solve the problem in a real prototype.
Ringing and oscillation can be virtually equivalent, if it's a resonance constantly perturbed, or if the oscillation is only sustained on negative half-waves or 5A excursions. It is best not to have any of either when it can be helped.
The Kmultiplier rail filter! LTSpice wiki with special attention to new users' troubles Last edited by keantoken; 17th April 2012 at 05:05 PM. |
#2426 |
#2427 |
Inverting SSA
There is no way out for the purpose mentioned earlier the amp must be inverting. Anyway with the feedback system shown earlier it has now a current input and a current output . But does this schematic make sense ? Of course it can be simulated. |
#2428 |
Distortion of the shunt compensation can be brought down considerably by applying the entire Symasym compensation scheme, after you have added drivers.
#2429 | |
#2430 | |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
