Simple Symetrical Amplifier
Old 4th April 2012, 02:57 PM   #2341
Sheldon is offline Sheldon  United States
Originally Posted by Lazy Cat View Post
So NTC is working properly, glad about that. If it is still undercompensated with 220 ohm, than try a little lower value ie. 180 ohm. Without serial compensation resistor it is always overcompensated.
Thanks. With the 220 Ohm resister shorted, compensation seems very good. I adjusted the driver bias to about 10mA warm, and output offset within 5mV. I then shut off power and allowed everything to cool completely.
Upon cold start up, the driver current quickly ramps to about 7.5mA, then rises over the next 20 seconds or so to about 9.5mA. After a couple more minutes, it rises to 10.0mA and stays there. Output offset wanders a little but less than +/- 15mA. Square waves look very good - no overshoot, with a very small amount of hF noise visible in the leading edge, at 100kHz (may be due to all the probes I have connected, or may have to adjust the HF compensation a bit?).
The temporary heatsink that I'm using for the output devices is barely adequate, so it gets fairly hot, but not too hot to touch. Only the outputs are mounted on this sink. The board you see in the picture is about 1.5cm above the output sink. As the outputs heat up, the driver bias drops to about 9.5mA. So it looks like no resistor or a maybe a small one is all that is required for this version. Yes, I believe that with no series resistor it is overcompensated for the input bias drift, but that overcompensation is needed to take care of the driver thermal drift, which is otherwise not compensated for.
As I noted before, the drivers in this version are not cascaded, so there is significant power dissipated. And the driver bias is visibly sensitive to driver temperature. I have a small square of aluminum as heat radiators for the drivers (about 1mmx1.5cmx1.5cm). If I put a finger on the driver sink (they are warm to the touch, but not hot) the bias immediately begins to drop and the offset climbs.
My analysis could be completely wrong, but the result is nevertheless good.
Sheldon
Old 5th April 2012, 12:52 PM   #2342
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Originally Posted by Sheldon View Post
Rat's nest.
I have seen bigger rats
Kindest regards
Nico
Old 7th April 2012, 07:21 AM   #2343
hahfran is offline hahfran  Germany
The BJT version of SSA posted here earlier shows as expected very unfortunate sensitivity to complex loads.
The simulation of a 2 way speaker is accurate within 95% of the measured complex impedance of the actual speaker. A critical situation for amps sensitive to reactive distortion is around 330 Hz. There the thd of the amp jumps sharply from less than 0.03% to above 0.6% and such is audible.
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 6.000e+01 2.378e+01 1.000e+00 -0.01 0.00
2 1.200e+02 2.606e-03 1.096e-04 -100.19 -100.18
3 1.800e+02 1.418e-03 5.964e-05 13.05 13.06
4 2.400e+02 3.070e-04 1.291e-05 99.87 99.88
5 3.000e+02 1.042e-04 4.383e-06 33.05 33.06
6 3.600e+02 6.801e-05 2.860e-06 36.28 36.29
7 4.200e+02 1.450e-04 6.097e-06 -2.20 -2.19
8 4.800e+02 7.435e-05 3.127e-06 -48.58 -48.56
9 5.400e+02 6.682e-05 2.811e-06 -54.96 -54.95
Total Harmonic Distortion: 0.012578%
but
1 3.300e+02 2.341e+01 1.000e+00 0.59 0.00
2 6.600e+02 4.036e-02 1.724e-03 116.46 115.87
3 9.900e+02 1.246e-01 5.323e-03 113.17 112.59
4 1.320e+03 2.305e-02 9.845e-04 43.14 42.55
5 1.650e+03 4.954e-02 2.116e-03 60.91 60.32
6 1.980e+03 2.034e-02 8.691e-04 -11.28 -11.87
7 2.310e+03 1.878e-02 8.023e-04 -18.24 -18.82
8 2.640e+03 1.905e-02 8.138e-04 -58.65 -59.24
9 2.970e+03 1.793e-02 7.659e-04 -128.37 -128.96
Total Harmonic Distortion: 0.627743%
Old 7th April 2012, 12:11 PM   #2344
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
It would be of interest to all of us, if you can verify in sim following tips to lower distortion in SSA:
- replace R26, R27 with CCS
- reduce R1, R2 to 100 ohm and R20, R21 proportionally, to maintain desired voltage gain
- reduce R9, R10 to few ohms to higher OLG
- cascode Q6, Q7
As partial solutions these tips were reported frequently as advancement but I don't remember if ever all of them simultaneously.
Regards Andrej
Old 7th April 2012, 01:12 PM   #2345
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
please give link for the diagram you refer to - thx
Old 7th April 2012, 01:52 PM   #2346
Actually ur last posted diagram does not have part numbers . . . .
Perhaps it's best to post a diagram with the question - if you want to ask questions about part numbers otherwise we can spend hours hunting through the thread and still may not find the diagram you had in mind . . . .
Old 7th April 2012, 09:47 PM   #2347
- cascode Q6, Q7
Regards Andrej
I have already reduced R1 R2 to 110 ohms and changed R20 R21 thus that full power is with 1.5 volts input, but that doesn't change the reactive distortion. I oticed further the op of the Vas is too low with roughly 4 mA
it should be 20 mA where /Ic linearity is good and ft is max.
I will also try to set the op of the predriver to 10 mA for the same reason because all planar BJTs of this size have their max ft at 10mA and also the max linearity /ic.
Will try CCS but am not convinced. We'll see.
Old 7th April 2012, 10:32 PM   #2348
Lazy Cat's Avatar
Originally Posted by MiiB View Post
I think the basic topology is tremendous. You have attacked the output in a unique manner..where you aim to remove the P to N differences. I have fitted a current dumping error correction circuit on the version I have built. which by the way sounds rather ok...
Now to the house keeping. I do believe that the weakest part of this fine circuit and the very reason why it does not simulate particularly well is the poor relations between the impedance of the current drive and the feedback currents. The basic amp is basically fed from a 1Kohm current source..which is way too low to prevent the feedback currents from modulating the drive-current. This is the main source of error in the circuit and by fitting high (very high) impedance current-sources specs are terrific. I will not show my housekeeping here....But I'am quite sure you catch the direction.
Old 7th April 2012, 10:53 PM   #2349
WHAT DIAGRAM !
Old 7th April 2012, 11:20 PM   #2350
Lazy Cat's Avatar
I am sorry mikelm, I apologize, I thought you were asking hahfran.
Well the parts I was comment are from hahfran's sch posted above in post #2343.
Simple Symetrical AmplifierHide this!Advertise here!
Symetrical schematics are alike plague in Brazil, do you like them? destroyer X Solid State 151 1st July 2010 02:09 PM
Symetrical out low Zout karsten21 Tubes / Valves 5 1st February 2010 10:19 PM
going balanced/symetrical - what benefits? weissi Solid State 15 20th October 2007 08:06 AM
Symetrical field, is this? Raka Multi-Way 6 14th September 2003 01:21 PM
Non-symetrical SMPS output cm961 Parts 4 21st August 2003 10:27 PM
