#2201 |
Thanks Jay, that explains why the conversation seemed to be going on ad infinitum.
It's funny though because I'm just about coming around to the idea that valves might be able to give more clarity & life than solid state - at least a valve front end. Perhaps it's the caps & iron that can end up sounding mellow ? ? mike |
#2202 | |
current driven all over non switching power section thermal compensation with thermaltrak BJTs under one umbrella. not enough spare time for that. |
#2203 | |
That is why these give more clarity . While there are some tube MOSFET hybrids no one has tried a tube BJT hybrid ..that could be interesting |
#2204 | |
BTW, I agree with you about the non-switching Class AB. I have tried this one too, over some years, but never found the benefits I expected sonically. I really don't think that the switching of the output stage is such a big problem as long as it's clean and well controlled. A good compromise is to ensure that the drivers never switch off. Hugh |
#2205 | |
Sheldon |
#2206 |
diyAudio Chief Moderator
I used low pinch off Jfets for that reason. Up to what level did the DN2540 hold before starting to chew up?
#2207 | |
Sheldon |
#2208 |
Was mild on ~zero gate current Latfet. Not for BJT output then.
#2209 | |
how would you bias the FETs for class AB? |
#2210 | |
if it were not about those tubes made in China and Russia having unknown quality I had possibly thought deeper on a kind of "current dumping" tube BJT hybrid where the tube supplies the voltage and the BJT supplies the current. BJTs are unbeatable if they do what they can do best, current amplification. Same stuff with speakers, speakers are current controlled not voltage controlled. |
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
