#2121 |
Bravo sonnya
![]() Plot represent mains AC current waveform as voltage drop on 1,00 ohm resistor (1 V on plot equals 1 A) as function of NTC soft-start circuit power-on sequence. After 0,68 s delay, relay contacts shorts the NTC and there's still 3 A current peak to fully charge elco bank of both (stereo) SSA channels. ![]() Here's plot with values. ![]() P.S. Serial NTC is CL-90 from GE. First power-on relay switch is dealing with some 2 Ap and second delay-on relay switch with some 3 Ap which is quite optimal for turning on two 400 VA toroidial transformers and some 90.000 uF of all elcos in power supply.
#2122 |
you are all wrong...
from my perspective that's a tsunami striking the beach ![]() cheers |
#2123 |
Before
#2124 |
After
#2125 |
Funny, that you posted pics. I was just gonna write how the project went for you.
#2126 |
Yeah cool thinking
![]() Well listening tests with simultaneous measuring check-ups is what's happening. SSA has now something like 20 hours of music burn-in time and I admit that now in stereo setup this is one of the greatest amp I ever experienced. Resolution and transparency is spooky, still presented in organic full spectrum sound. Low part of the spectrum is amazing, how amp effortlessly drives bass notes is simply astonishing. That's enough of words but every one of them is pure truth.
#2127 |
I think it is time that we in europe starts constructing something new and innovative like this amp, The FETzilla.
Most amps you find on the market or in this forum are mostly ripoffs of old RCA, krell, Mark xxx, Pass constructions.... Only on the CLASS D there is happening some innovation.. The most active designer around as i see it is Holton from Aussie amplifier |
#2128 |
#2129 | |
Just DIY!
![]() Ripoff or not, it is the diy world. people want to learn and experience. And btw, Pass is supporting diy efforts. However, true, the FetZilla is really good and I have built it along with many "ripoff" amplifiers that sound extremely good! Good thing I'm in America! ![]() Do
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2 |
#2130 |
LC, may I know where is the PC layout diagrma of your SSA BIGBT HP ? wanted to take a look at the reference, may I ?
| Symetrical schematics are alike plague in Brazil, do you like them? | destroyer X | Solid State | 151 | 1st July 2010 02:09 PM |
| Symetrical out low Zout | karsten21 | Tubes / Valves | 5 | 1st February 2010 10:19 PM |
| going balanced/symetrical - what benefits? | weissi | Solid State | 15 | 20th October 2007 08:06 AM |
| Symetrical field, is this? | Raka | Multi-Way | 6 | 14th September 2003 01:21 PM |
| Non-symetrical SMPS output | cm961 | Parts | 4 | 21st August 2003 10:27 PM |
